WL CLoud network support in Version 4.2
Yes, green marks
Gert
Gert
- 2019-10-25 (3).png (29.19 KiB) Viewed 6858 times
hm, can you please give me a remote login, so that I can look at more detail what is going on? Please mail URL and password to "info(at)meteobridge.com". Thanks.
- lightmaster
- Junior Boarder
Boris, superduty is have a similar issue as gand except his isn't showing the green check on the live data page. Settings all look okay to me.
yes, I think I will need a remote login to find out the root cause.
Boris,
I have sent my login information to you.
Thank you for your help.
Thanks for sharing login credentials. Looks like MR3020 V1.x did not work correctly with HTTP PUT. Changed on all platforms to HTTP POST with just released update and now it seems to work fine. Please check and come back if you face problems again.
Hi Boris
Will this include MR3020 V3 as well? I'm using V3.
Rgds
gand
Rgds
gand
@gand: Your console is on very old FW version 1.75, which does not support LOOP2 packets. I made and just released a fix that supplements for non-existing LOOP2 data, but I recommend to upgrade your console firmware. Data seems to come in fine now on your account.
Hi Boris
Seems to work now, at least I have some data in WL. I'll take a closer look at the data and check with MB and do a verification.
Thanks for great support.
Rgds
Gert
Rgds
Gert
Hi Boris
Thanks for your support.
It's working perfect now and I'll try to see if I can upgrade the console to a newer version
BTW, how often would you recommend uploading to WL. Currently I'm uploading every minute.
Thanks again.
Rgds
Gert
Thanks again.
Rgds
Gert
admin wrote: Fri Oct 25, 2019 10:58 pm Thanks for sharing login credentials. Looks like MR3020 V1.x did not work correctly with HTTP PUT. Changed on all platforms to HTTP POST with just released update and now it seems to work fine. Please check and come back if you face problems again.
You are speaking a language I don't understand with regards to the HTTP PUT and POST..... But thank you very much for how quickly you remedied the issue.
As some of the Meteobridge users here in the forum are deep into IT, I try to mention at least what kind of change I did. Please ignore when it is not making sense to you.
Davis products are uploading every 10 minutes when I remember correctly.gand wrote: Sat Oct 26, 2019 12:00 amBTW, how often would you recommend uploading to WL. Currently I'm uploading every minute.
- lightmaster
- Junior Boarder
Ive got mine uploading every minute and haven't had any issues.
meteolive57290
- Senior Boarder
Hello to all,
thanks for the work and MB support
i already use a WL_IP monitoring with the device MB-Pro
i did the "test" with the identifiers of a former faulty old WL_IP
after recreating a WL 2.0 account (MeteoLive MB @ Pro)
make the update FW of the MB-Pro ret add the support WL-Cloud
it works without problems
i have the uoplad datas on the new platform Davis
enjoy !!
enjoy !!
- Capture.PNG (63.87 KiB) Viewed 6800 times
