I upload weather data to Twitter every hour.
I use [mbsystem-sunrise], [mbsystem-sunset], [mbsystem-daylength]
11/1-2020 kl. 23:00 - Sunrise 08:33, Sunset 16:02, Daylength 07:28
12/1-2020 kl. 00:00 - Sunrise 08:33, Sunset 16:03, Daylength 07:31
I have attached a screenshot from Twitter, where you can see that it says Daylength has increased from 07:28 to 07:31 = 3 min.
If you look at the Sunrise it has not changed - Sunset has only increased with one minute. So the Daylength has only increased with 1 min.
If you calculate the Daylength, the correct Daylength is:
Sunrise 08:33, Sunset 16:02, Daylength 07:29
Sunrise 08:33, Sunset 16:03, Daylength 07:30
My Twitter upload:
https://twitter.com/frbvejret
Danish > English:
Sol op = Sunrise
Sol Ned = Sunset
Længde = Daylength
Calculate wrong Daylength [mbsystem-daylength]
cphMichael
- Junior Boarder
- Twitter.png (81.66 KiB) Viewed 1391 times
Re: Calculate wrong Daylength [mbsystem-daylength]
Meteobridge uses a lib for that. I can't change the formula, so you have to live with it.
