502 Bad Gateway errors. **solved**
gcams
Post by gcams »
Getting frequent 502 Bad gateway errors from the Meteoplug web server just now which is making a bit of a mess of my website with the embedded iframes. Can you look into this please??
Screen Shot 2020-02-01 at 08.47.58.png (25.23 KiB) Viewed 14347 times
grwkak
Re: 502 Bad Gateway errors
Post by grwkak »
Its been happening since the transition to the new server. On and off - I don't see a pattern.
See it right now on my Meteobridge (Meteoplug Cloud (live)):
http://logger.meteoplug.com/cgi-bin/live.pl: 2020-02-01 09:52:09 ERROR 502: Bad Gateway. (no more tries)
Guy
gcams
Post by gcams »
grwkak wrote: Sat Feb 01, 2020 4:51 pm Its been happening since the transition to the new server. On and off - I don't see a pattern.
Yes I agree this started with the server change and occasionally occurs but it's been particularly bad in the last 24 hours or so.
I originally posted about it here and got no response:
viewtopic.php?f=63&t=14533&start=15#p31393
But right now it's so bad my website visitors are complaining.
frabey
Post by frabey »
Hallo Boris,
Was ist mit dem Server los? Immer wieder der 502er Fehler seit dem Serverwechsel.
Seit du Meteoplug veröffentlicht hast gab es nie solche starken Probleme.Erst in letzter Zeit zeigt Serverstatus ist auch sehr häufigen Serverausfall bzw. fehlen die Auslastungsdaten daten.
Wäre super wenn das System wieder vernünftig laufen würde.
gcams
Post by gcams »
The 502 errors still continue frequently today as well. It would be great to get an update on this issue.
Screen Shot 2020-02-02 at 13.53.45.png (14.8 KiB) Viewed 14320 times
grwkak
Post by grwkak »
I posted in the Meteobridge forum on this topic. Hoping someone can look at this. It also affects my iframes on my website.
Guy
Rutishauser
Post by Rutishauser »
frabey wrote: Sat Feb 01, 2020 7:37 pm Hallo Boris,
Hallo zusammen
Ich schliesse mich dem an: Seit dem Serverwechsel kommen diese Fehler teilweise häufig.
Zudem ist das bearbeiten der Grafikdefintionen zum Teil unmöglich geworden...
Please read the other posting about live data services. Operation should be now fine again.
Stormedy
Post by Stormedy »
Dear Boris, I contacted Kai Kobler (Kaiko) yesterday about the Bad Gateway errors. It is now functioning but on my weather page the Meteoplug live graphic is not functioning! I think also with Kaikos Weather page!
Can you check my website: http://www.kaikowetter.ch/mc/meteoplug_seegrabenX.html
on the live graphic including the wind compass does not show any data!
Thanks for your info - hope this will be in order soon!
regards
Edward
