More intermittent 502 Bad Gateway errors! **solved**
gcams
Post by gcams »
My Meteoplug iframes are again seeing intermittent 502 Bad Gateway errors, and similarly when trying to login into login.meteoplug.com :shock:
This seems to be an ongoing issue since the server was migrated and it's really unfortunately impacting the quality of service. :(
Screenshot from 2020-02-28 10-44-09.png (22.21 KiB) Viewed 10284 times
grwkak
Re: More intermittent 502 Bad Gatway errors!
Post by grwkak »
Seeing the same thing today. Was gone for a while.
Guy
We finally converted one of the central data delivery scripts from perl to php, which is much better supported by nginx. Any load problems should be gone now. We expect no more 502 ;-)
Rutishauser
Re: More intermittent 502 Bad Gateway errors! **solved**
Post by Rutishauser »
Thank you! :)
