Hi all, today I installed Meteohub running under VMware.
I have a WMR200 weather station connect by USB to my PC but I don't get any sensor reading by Meteohub.
The station is running fine with Weatherdisplay so the station has no problems.
Weather display is not running and the PC is rebooted with no drivers from WD or so loaded.
WMR200, no sensors found
- HeinrichH
Checking the remote....
skyewright
Re:WMR200, no sensors found
Have you assigned/attached[1] the USB port to the Virtual Machine?
[1] I'm at the wrong computer and can't recall the exact word that is appropriate.
- HeinrichH
I don't know, how can I assign a USB port to a virtual machine?
as explained here: http://www.meteohub.de/joomla/index.php ... &Itemid=73
"During boot of virtual machine USB components connected to the PC will be displayed. One of these should be the connected weather station and/or USB webcam. Make the needed components connected to Meteohub by selecting corresponding icons on the lower right border of VMware window and setting these as not being connected to the host."
