Problem with Meteobridge Pro **solved**
aldogailla
Post by aldogailla »
Hi ,
i need help to find what is this error "database (07.03.2020 00:19:28): failed with step exist record on uv0lowbat_hour (after 0 retries in 6ms): database disk image is malformed (11)"
What is it? i never find in other discussion this problem.
This is debug of my meteobridge
oled (06.03.2020 23:14:00): process started.
database (07.03.2020 00:19:13): process started.
database (07.03.2020 00:19:13): Content of RAM database restored.
wnetd (07.03.2020 00:19:15): process started.
system (07.03.2020 00:19:15): start of logging process initiated.
wnetd (07.03.2020 00:19:15): send data thread started (pid:2270 tid:2271)
logger (07.03.2020 00:19:16): databases connected. Update interval 3600 seconds.
logger (07.03.2020 00:19:16): data logger (version 5.1c, build 13419) started.
logger (07.03.2020 00:19:18): connect station 0 (Meteostick Vantage via USB serial).
logger (07.03.2020 00:19:18): connect station 9 (System Data via Plug-in).
logger (07.03.2020 00:19:20): transmitter 1 registered as ISS
logger (07.03.2020 00:19:20): Meteostick Version 2.5.2
logger (07.03.2020 00:19:20): debug off
logger (07.03.2020 00:19:20): verbose off
logger (07.03.2020 00:19:20): output raw (8 bytes)
logger (07.03.2020 00:19:20): output raw (10 bytes)
logger (07.03.2020 00:19:20): filter on
logger (07.03.2020 00:19:20): rx threshold set to -85db
logger (07.03.2020 00:19:20): listening to transmitter 1
logger (07.03.2020 00:19:20): bandwidth narrow
logger (07.03.2020 00:19:20): chip authentication ok: 14
logger (07.03.2020 00:19:20): frequency band 868MHz (EU)
logger (07.03.2020 00:19:21): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (07.03.2020 00:19:21): services paused.
database (07.03.2020 00:19:28): rollback on sync forced (min): uv0lowbat
database (07.03.2020 00:20:08): failed with step 1 on th0lowbat_hour (after 0 retries in 1ms): database disk image is malformed (11)
database (07.03.2020 00:20:08): rollback on insert forced (2) (hour): th0lowbat
database (07.03.2020 00:20:09): failed with step 1 on th0lowbat_hour (after 0 retries in 11ms): database disk image is malformed (11)
database (07.03.2020 00:20:09): rollback on insert forced (2) (hour): th0lowbat
database (07.03.2020 00:20:09): failed with step 1 on th0lowbat_hour (after 0 retries in 1ms): database disk image is malformed (11)
Re: Problem with Meteobridge Pro
Please select "forced rebuild on boot" option on "system" tab and do a reboot. It will take some time to rebuild the database.
aldogailla
The problem is resolved. I follow your advice.
Thank you very much
