I'm not sure when this changed, but the "last update" time on the live-display always used to represent the local timezone (the Time Zone set in the Meteoplug control panel). However I noticed today that it is showing UTC instead of obeying the Time Zone setting.
Example - My config Time Zone is set to Australia/Melbourne
But my Live dashboard is showing time in UTC:
The time zone is correct however on the Meteoplug map (screenshot taken a minute later than above):
Is it possible to correct this please? My site visitors keep thinking the data is old when it's actually current, just the wrong timezone.
Thank you.
Live display shows UTC instead of configured time zone **solved**
Re: Live display shows UTC instead of configured time zone
Yes, the same as with me but unfortunately that interests again nobody
Yes it's definitely not ideal, as folk think the data is out of date/old!
Can you please send the Meteoplug account name to "info(at)meteoplug.com"?
E-mail on it's way to you thanks Boris.admin wrote: Fri Apr 10, 2020 7:01 pm Can you please send the Meteoplug account name to "info(at)meteoplug.com"?
lorenz1982
- Expert Boarder
I have the same problem.
- Annotazione 2020-04-21 172837.jpg (27.25 KiB) Viewed 15282 times
Issue with GMT instead of local time has just been fixed for the live dashboard.
Thank you Boris! I can confirm it's looking good at my end now!admin wrote: Fri Apr 24, 2020 1:54 pm Issue with GMT instead of local time has just been fixed for the live dashboard.
lorenz1982
- Expert Boarder
