Hello everybody ,
my meteobridge has been standing still for about 2 days. No more data is uploaded. A restart then usually helps.
I found this message here.
logger (21.04.2020 04:50:18): error writing logged data to pipe "gzip >/var/run/meteohub/inetupload.z": Bad file descriptor
Go back to version 4.2. Let's see what happens.
Greetings daniel
Suddenly everything just stops... **solved**
Re: Suddenly everything just stops ...
That must be another problem. Even with version 4.2 the system works with the same Error..
Buffer was always 100% before restart.
- 1.jpg (61.09 KiB) Viewed 1626 times
Re: Suddenly everything just stops ...(solved)
Hello everybody,
the system has been working without problems for 3 days now.
Greeting
Daniel
Greeting
Daniel
