- processed data records per second (from "meteohub log" )
- platform (NSLU2 133MHz, ALIX.1D, etc...)
- storage media (type of USB Stick, SSD, CF card, etc)
How fast is recomputation? Version 3.2d reports numbers!
Let's make use of the feature of Version 3.2d to report recomputation speed for you Meteohub system. Beside the platform itself, I will expect the storage media to have a major impact as well. So please tell us your...
Re:How fast is recomputation? Version 3.2d reports numbers!
- 14612451 records processed in 7265 seconds (2011 records per second)
- fit-PC Slim
- Transcend SSD TS8GSSD25-S
Meteohub on my server's VMware is even quite a bit faster :-)
- 14153300 records processed in 766 seconds (18476 records per second)
- VMware Server 2.0, Core2Duo, 3GHz
Here good old NSLU2 as reference
- 14179626 records processed in 29704 seconds (477 records per second)
- NSLU2 266 MHz
- 4GB USB stick OCZ ATV
skyewright
- 7877937 records processed in 21277 seconds (370 records per second)
- NSLU2 266 MHz
- 4GB USB Freecom Databar
Load during recompute: Reading from USB RFXCOM, updating one html template @ 15 minute intervals, feeding WD by TCP/IP protocol, another Meteohub (ALIX 1D) observing port 5557.
Memory age: 9 months
skyewright
- 7879599 records processed in 4193 seconds (1879 records per second)
- ALIX 1D
- 4GB iCF 4000 Dual Channel Industrial Compact Flash - 266X
Load during recompute: Reading from NSLU2 Meteohub by TCP/IP, updating one html template @ 15 minute intervals.
Memory age: New
# 5371448 records processed in 5021 seconds (1069 records per second)
# NSLU2 266 MHz
# Corsair USB Flash Voyager 4GB
Looks like the memory makes a difference. :)
# NSLU2 266 MHz
skyewright
Seems likely.pirelli wrote:Looks like the memory makes a difference. :)
I just edited my posts to add in a few more details (nature of data, load during recompute, and age of the memory device) in case that helps build a better picture.
It might be interesting for me to try again after I have switched the ALIX 1D over to being the main device (i.e. after swaping the "load during recompute" characteristics from NSLU2 => ALIX 1D and vice versa).
- 912268 records processed in 741 seconds (1231 records per second)
- eBox 4300 (eTC-2500), 512MB RAM
- 4GB CF
- 4GB CF
skyewright
The figures for the ALIX 1D as "main device" (i.e. with a higher load during recompute) were almost identical at 1804 records per second.skyewright wrote:It might be interesting for me to try again after I have switched the ALIX 1D over to being the main device (i.e. after swaping the "load during recompute" characteristics from NSLU2 => ALIX 1D and vice versa).
I can't compare against the NSLU2 as "secondary" at present, because the file system on its USB stick failed and I haven't yet rebuilt it...
Version 3.3 report.
recomputation of weather data finished: 145206 records processed in 84 seconds (1728 records per second)
system'ALIX 1 d
4 G. card
Update time every 10 minutes by cresta wxr 815
Power consumption 5,3 watt maximum !!
Paul
system'ALIX 1 d
4 G. card
Paul
[*]4972334 records processed in 2604 seconds (1909 records per second)
[*]Alix.3C2
[*]4GB NoName CF-Card
[*]Alix.3C2
I see you have it running on ALIX.3C2. Very interesting, as I have not tested this. Difference between C and D models does not seem to be to much, but anyway good to know.
I ordered Alix3D2 but was supplied with Alix.3C2 (Varia-Store). The 3C2 seems to be the predecessor of 3D2 but works fine so far. The MeteoHub System Info indicates a 3D2, but a print on the circuit board and the invoice from Varia-Store tell me its a 3C2.
juergen_h.
- Junior Boarder
- V3.3
- 3152527 records processed in 1377 seconds
- (2289 records per second)
- fit-PC slim with 4GB Transcend SSD
Juergen
Juergen
