Hello
I've been a licensed customer since 2008. I'm currently running 5.1d on Rasperry 3B. SMB shares is running as reported by System Info. However access from a Window PC does not work (\\myIP\data for example fails to open the folders). Is it a known issue? Thank you
SMB access fails
- Expert Boarder
Re: SMB access fails
Thanks to this post viewtopic.php?f=60&t=14627&p=31934&hili ... ess#p31934 I managed to restore access the SMB share. However /public/uploads fire up a "you have not the privilege to access it". Rights on the folder are Read for everyone. All other folders are accessible. How can I access the upload folder?
