Hello
I work with the call
http://ip-of-meteobridge/cgi-bin/livedataxml.cgi
My device is a TL-MR3020 V 3.2 WeatherBoxx easy.
If I make the call via Wifi, only one of four attempts will work. If it works, the data will be displayed correctly as XML - File, as shown in the wiki. But it takes very long until this display appears on the browser. The other three times, the call runs into a timeouts and aborts.
What can be the reason for this? I am working with this call internally in the network, i.e. in house, and not from outside.
I want to store the information from the XML file in HomeMatic in system variables to use them for different calculations
I‘m working with a FritzBox.
Thank you very much for your help.
Livedataxml.cgi over Wifi
Re: Livedataxml.cgi over Wifi
I am aware that my question is not easy to answer. But how could I proceed to trace the cause. The data transfer to Wunderground or meteomap.cloud works best over Wifi. But this retrieval of the XML file does not work properly.
