difference meteobridge?
Ger
Post by Ger »
I have 2 station, a TL-MR3020 and a NANO SD . For both I use meteobridge 4.3.
But the SW with the TL-MR3020 paltform doesn't have Graphics, is that intentional? If so, can I buy an upgrade?
Re: difference meteobridge?
Ger wrote: Sun Jun 28, 2020 2:12 pm I have 2 station, a TL-MR3020 and a NANO SD . For both I use meteobridge 4.3.
The MB-Nano and the MB-Pro have large internal storage so there is enough room to store forever all high-low values of all sensors.
That storage also does not get lost when rebooting.
The "normal" MB has nearly no storage at all and can only store the high-lows in memory and save them to an external (meteoplug) server.
When rebooting a normal MB the small set of high-lows need to be reloaded from the server.
The graphs need large data-sets to draw the graphs so they are only available with the MB-Nano and MB-Pro
https://www.meteobridge.com/wiki/index.php/Features, also applicable for then Nano
Additional Features of the PRO
The Meteobridge PRO offers these additional features
local storage of all sensor data in a 60 minute resolution
automated backup of stored data to a USB thumb drive
editing of stored data
expanding template replacement mechanism to data stored further in the past
display of user-defined data
export of data in user-defined formats
generation of user-defined graphs
logging system data like power consumption, climate inside the box and various system status information
access to data via SMB share (pc network folder)
Ger
Post by Ger »
Thanks Wim, so I need another nano. I buy it tomorrow.
galfert
Post by galfert »
You can also get a MB Pro Black. It doesn't need a console to work. It will get data from WLL or IP logger or from other USB logger.
Meteobridge RPI | GW1000
