User-defined Charts
User-defined Charts
Version 4.1 introduces the concept of "Meta Charts" which allow users very easily to define their own individual charts. It just needs some declarations and a broad variety of charts can be designed. Please have a look at this link to understand how meta charts can be defined.
https://www.meteobridge.com/wiki/index. ... Definition
Please inspect the example definition and result below. It cannot be much easier.
Meta chart definition:
# meta chart for Temperature and Humidity
title Temp/Hum Chart
type line
data1 th0temp-avg=F.1
data2 th0hum-avg.0
data3 th0dew-avg=F.1
name1 Temperature
name2 Humidity
name3 Dewpoint
axis1 left
axis2 right
axis3 axis1
active1 yes
active2 yes
active3 no
unit1 ..F
unit2 %
unit3 ..F
color1 #10E010
color2 #4430FF
color3 #E01010
min2 0
max2 100
Resulting chart:
Screenshot 2019-08-19 at 23.31.13.png (212.07 KiB) Viewed 33147 times
Ger
Re: User-defined Charts
Post by Ger »
How can I find the folder in the network? I see several items in the network tab (printer/ archer_MR400) but not the meteobridge.
The charts are located on the internal storage and can be access as a PC network drive in forder "templates"
"templates" folder is under \\your-mbpro-ip\data\
Ger
Post by Ger »
Thanks, I can now edit the charts. But I want change the dateformat in dd mm yyyy , wind in Bft and add windchill. Where can I find instructions for those changes?
I copied windchill from hws-temphum-iso chart and insert it into the renamed allin-one-iso chart. But it doesn' t work for me
"fromField": "c",
"toField": "chill"
and
"id": "g3",
"valueField": "chill",
"valueAxis": "v1",
"type": "line",
"title": mbtext['windchill'],
"hidden": false,
"lineThickness": 1,
"lineColor": "#ff3399",
"useDataSetColors" : false,
"fillAlphas": 0,
"visibleInLegend": true,
"legendValueText": "[[value]]°C",
"connect": false,
"gapPeriod": gap,
"balloonText" : "[[title]]: [[value]]°C"
AMCharts is used for graphing. So you might want to read in their documentation to generate individual charts beyond the metacharts. But this needs some work on your own, I cannot support you on this.
masgio69
Post by masgio69 »
Hi, I can't export the graphs via the url remote chart, it tells me that "remote acces to your meteobridge is currently not avaiable. Please try later and / or reboot your device." Of course I have already restarted the meteobridge and all the other functions are all ok. What could it be?
It has nothing to do with the charts. It is about the remote connection currently not working in general.
reiry01
Post by reiry01 »
Hi all,
kurz in Deutsch weiß jemand wie man die Windrichtung mit den Y ordinaten W- S- O- N darstellt?
In der festen iso Chart ist sowas abgebildet.
Wenn ich aber das selber im Chart definieren machen möchte keine Ahnung (es lassen sich nur grad einstellen)
Hi anyone now how is in wind direction chart the y ordinat in signs N W S O defintion posibale?
Beispiel:
Screenshot 2022-11-11 at 13-54-15 Meteobridge.png (63.84 KiB) Viewed 17599 times
Yes in iso it excist but here?:
Screenshot 2022-11-11 at 13-59-31 Meteobridge.png (36.57 KiB) Viewed 17598 times
Most predefined charts are not generated via metachart option and therefore, can do a bit more magic. I will check if I can also implement this feature for metacharts.
reiry01
Post by reiry01 »
Super that can especially: Private airfields; sailing clubs and surf clubs very much need THANKS :D
Cool would be also, a wind rose template.
Or gauge template mechanisms in the Meteobridge. :D
WS Grave
Post by WS Grave »
Any update on the possibility to show the wind direction in N / S / E / W?
zakos52
Post by zakos52 »
“Any update on the possibility to show the wind direction in N / S / E / W?”
I am also waiting for this update from November 2022!
reiry01
Post by reiry01 »
Is now an update where we can have had those Winddirection? Yes, than i will also update my Lizense! :D 8) or No then no :lol:
