Weather 34 built into Nano SD
BigAlT
Re: Weather 34 built into Nano SD
Post by BigAlT »
Boris,
Thank you. I never would have figured out how to load the new dashboard.
Allan
BigAlT
Post by BigAlT »
I followed Boris’s instructions to load the most current version of the dashboard and it works fine. I do find that the Wunderground Forecast doesn’t load at all, I just get a blank screen when trying to show it. I’ve gotten and inserted a new Wunderground API key in the Nano SD Weather 34 Dashboard settings. Looking at my Wunderground API useage it shows a straight line of errors. Anyone have the same issue or is it related to the 2021 termination of the forecast API ?.
Even more confusing is that if I load the original dashboard version ( you can view both of them ) the forecast is displayed correctly.
garybridge
Re: Weather 34 built into Nano SD ( purple air)
Post by garybridge »
I have placed the Id of my Purple Air sensor into the template, hit save configuration.
The purple Air logo appears at the bottom of the template but the data is blank?
I’ve checked for white space before and after the ID data, all seems ok.
Works fine on my external website.
Gary
Gary Bridge MIET, MIPS.
36260
Post by 36260 »
BigAlT wrote: Sat Oct 03, 2020 12:56 am I followed Boris’s instructions to load the most current version of the dashboard and it works fine. I do find that the Wunderground Forecast doesn’t load at all, I just get a blank screen when trying to show it. I’ve gotten and inserted a new Wunderground API key in the Nano SD Weather 34 Dashboard settings. Looking at my Wunderground API useage it shows a straight line of errors. Anyone have the same issue or is it related to the 2021 termination of the forecast API ?.
11816721-EE5C-46E1-98E2-909C312A9EB4.jpeg76FF5676-A4AA-4A5F-A3FF-391598628205.jpeg975B2E43-0A9C-4929-BDA0-4EAF4FE376E0.jpeg
Same with me. Running build 3470
Davis VP2 + Solar - Nano SD
garybridge
Mine WU is working fine.
Do you use WU on a anything else ? So that you can check the new key works?
Make sure you don’t have a leading or trailing space....
36260
Post by 36260 »
As a matter of fact, my api key is setup but forecast are NOT related to my location. Forecast is correct using PWS. Yes I'm using the same API for other purpose. This is why I may say that forecast is totaly wrong using PWS2
garybridge
Now I am further confused...
I thought that that the original template built into the Nano used a “Dark Sky” api for its Forecast data but used WU for historical data.
Where in the original template are you putting a WU API key?
garybridge
garybridge wrote: Wed Oct 07, 2020 11:27 am I have placed the Id of my Purple Air sensor into the template, hit save configuration.
Gary
Further to the above, I tried adding my purple air ID to the original weather dashboard, That also doesn’t work, the template comes up with “Fatal Error” and a message about memory allocation
Could this be related?
36260
Post by 36260 »
garybridge wrote: Sun Oct 11, 2020 10:44 am Now I am further confused...
WU API key is for PWS2.
BigAlT
Post by BigAlT »
I finally got the WU forecast working. First, I was using an api from another WU Station ID which I had created earlier. After getting a WU api for the correct station ID which I was using for WU on my Nano SD and copying it to the Weather 34 new template settings page and saving it, I went to the Weather Dashboard tab under the Live Data Tab. I checked the feed Dashboard with Data Box, hit the save button and then hit the launch dashboard button. Both the current forecast and 5 day forecast work as they should.
36260
Post by 36260 »
As you did, I hit the launch dashboard button after setting the API key and forecast is displayed correctly
