Sensor Mapping
WETRHE
Sensor Mapping
Post by WETRHE »
is it possible to map the Extra #1 Temp-Sensor t1 to Bodentemp.?
I am asking because I would like to have field 014 in clientraw.txt filled with the value from Extra #1 Temp-Sensor t1.
Or is there a possibility to edit the template from which clientraw.txt is generated directly? Haven't found this template so far.
Thx
Re: Sensor Mapping
Sorry, currently only "th" sensors can be selected, no "t" sensors. There is no external template file for this, it is hard coded.
WETRHE
Re: Sensor Mapping
Post by WETRHE »
admin wrote: Wed Oct 21, 2020 11:05 pm There is no external template file for this, it is hard coded.
Will there be a template for clientraw, clientrawextra, clientrawdaily etc.in future? This would be very helpful.
I tried to use an own template with the same structure of clientwar.txt in “Ereignisse” – “FTP-Hochladen” but unfortunately this isn’t working at all.
Re: Sensor Mapping
My development focus is not to best feed WD-Live. It is more a legacy function as there are today far more interesting options like weather34, to name just one.
WETRHE
Re: Sensor Mapping
Post by WETRHE »
OK, understand. But actually I am not using this function to feed WD Live but I need the clientraw to feed my WordPress Weather Plugin. Therefore it would be nice to customize the clientraw.txt a bit.
