Hello Brian,
If the default path to MBrealtimeupload.txt is not used, the update time at the top of the header is incorrect.
- Bildschirmfoto 2020-11-06 um 13.19.56.png (14.79 KiB) Viewed 7270 times
The associated script evaluates only the upload time of MBrealtimeupload.txt in the standard directory. if i copy the actual file MBrealtimeupload.txt to the standard-directory, also the update-time is actualized.
- Bildschirmfoto 2020-11-06 um 13.19.37.png (62.39 KiB) Viewed 7270 times
Is it still possible to adapt it, so that the real associated path to MBrealtimeupload.txt is also considered to update the upload time? The displayed data on the screen are updated correctly (e.g. every 30 seconds on my setup).
I assume that the air quality graphics will be activated in later versions, when the MB-API has been adapted?
Otherwise Aurora is a really nice update, thank you very much for your work!
Best regards and stay healthy,
Mike
