@chuck a reboot of your meteobridge device will fix that requires new API structure updated by Boris earlier in the week to read averages for Air Quality..
@xray77 I cant replicate what your seeing locally but I think all it needs is a small code change to cater for wild paths . so download the simple update from info page and run it again.
woolfg
Post by woolfg »
Hi Brian
Just rebooted my Meteobridge and am now getting a last updated of 51 years
Graham
graham that dont make sense why would rebooting meteobridge cause that ? the file updated has nothing todo with meteobridge itself . something locally ?
woolfg
Post by woolfg »
Hi Brian
I also did an Aurora update at the same time
Graham
some servers do not like the use of direct http especially none secure paths I have changed yours to the correct recommended method mbridge/MBrealtimeupload.txt
please check now
woolfg
Post by woolfg »
Hi Brian
OK -understood
Its all fine now
Graham
its ok template was designed to use simple path in the setup mbridge/MBrealtimeupload.txt obviously some like to do it in other ways or some server configurations dont object to use of direct http domain paths..anyway stick to the basics it always works :D
xray77
Post by xray77 »
it works fine now! Thank you for the fast update!
regards
Mike
xray77
Post by xray77 »
I can't display any graphics to air-quality (Davis AirLink and Luftdaten successfully configured in setup) in the day/month-graphs.. (e.g. consolecharts.php, consolecharts-month.php etc)...
Are there only data from "purpleAir"-Sensors implemented?
Is there an special reason why not implemented the other Air-Quality-Sensors?
Excuse my impertinent questions, but I don't understand why the other Air-Quality-Sensors can't appear in the graphics... Maybe you can enlighten me and other users about this, that would be nice.
Maybe it's a bug in my setup and normally it should work with the other Air-Quality-Sensors as well?
Thank you and have a good night, hope you were able to successfully winterize your roof?
best regards
Mike
terminology mike do you mean charts ? if so as per earlier post in the week i need a weeks worth of data for the new api values to work as expected . in the case of airlink its going to be seen if everyone is using the same configuration in meteobridge itself.
the new api values were only added this week so by end of weekend i will have enough data from various user sites to know wether it is working as expected then ill simply release the charts for month,year option. luftdaten will have to wait as its better to just focus on one thing then move onto next .. yes at present purple air is the only method fully supported for charts in day,month,year. then we also need to look at where does it go some users like yourself have multiple air quality sensors so my thinking is to create a dedicated chart air quality page separate from the weather data charts.. so patience is the keyword.. :D
xray77
Post by xray77 »
Good morning Brian,
Thanks for the clarification. So it's all good, I thought there was something wrong with my template in the settings or something.
I was surprised that Purple Air was included in the daily graphic (had seen it with other users who have Purple Air) but not Davis or Luftdaten.
Now that I know that this is still in development I will take your advice and be patient. :-)
Thank you again for your tireless work and the great willingness to help here in the forum, that's very nice and often not really usual.
Now I wish you a nice weekend,
Best regards
Mike
thanks ... this is where I am at but Im not confident of releasing this for at least another week simply need to apply options without it all becoming another headache.I dont think at this stage any luftdaten chart data will be implemented only Purple air and Davis airlink .simply because I have reliable access to data for these products and monitor data reliably .
building an air quality page a work in progress but at least a week possibly more away..
Screenshot at Nov 07 21-46-06.jpg (99.86 KiB) Viewed 7846 times
xray77
Post by xray77 »
This looks very good, I will be looking forward to it!
Off topic: I am now also happy about the outcome of the US election, it's a good evening for me.. ;-)
Thanks for you,
stay healthy
best regards
Mike
garybridge
Post by garybridge »
Loving the new Template, it truly is a work of Art & Science. :D
May I ask a question about the Moon Phase Module, I use the Sun and UV module on the main page, but as I have no lightning detector, I liked to have the moon in position 12, however it is unavailable for selection, but is available for the almanac page, however if I select it, the phase isn’t shown just the rise and set times.
Gary
Gary Bridge MIET, MIPS.
good morning Gary
just run the update should resolve that . it was missing from download has I had not removed the $lang scripts from the module sorry my oversight..
(*Aurora Update File for 8th November)
* Adds small missing moonphase module
* Preps for new additional air quality charts data
* IOS 14.2 iPhone/iPad Safari css alignmnet for overflow
* Adds Option for all Air Quality (Indoors or Outside)
* Formats time as per option set in Air Quality popups
forgot to add listing notifications are now themed according to dark or light .
