What do I do now? ** solved **
Re: What do I do now?
The first thing you should do is test if the URL produces an image on your browser from your camera. Just enter the URL into your browser's address bar. If it works and you see the image then you can use that URL in the Meteobridge. Then you can check under the Weather Station tab of the Meteobridge if the upload to Meteobridge.com produces an image when you click on the camera icon (with or with +text).
Meteobridge RPI | GW1000
- Expert Boarder
So this is what I get after typing the URL in the browser:
<CGI_Result>
<result>-2</result>
</CGI_Result>
<CGI_Result>
<result>-2</result>
</CGI_Result>
- Fresh Boarder
Are any of these devices on a Guest wireless network?
TL-MR3020 (WEATHERBRIDGE)
Meteobridge 5.0 (Oct 31 2020, build 14008), FW 1.4
Ecowitt GW1000
Ambient WS-2000
Ecowitt GW1000
Ambient WS-2000
- Expert Boarder
No sir, all running on 2.4ghz Netgear Orbi router.
I suggest updating the firmware on your Foscam camera.
Then try this URL:
http://ip address:port/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=xxx
Then try this URL:
- Expert Boarder
No go! Hey, no big deal. I just thought it would be nice to be able to upload to sites that wanted an URL. Thanks for all your help.
Re: What do I do now? ** solved **
Problem solved - TeamViewer to the rescue.
