thanks to graham ... http://ringwoodweather.ddns.net/Aurora/ ... charts.php
simple update now includes an option to show air quality data page if you have both purple air and Davis airlink if not all data can viewed by existing small module links .please allow a week for the charts for month year to grow and populate at end of each day..
Just uploaded the latest and the new AQI charts page is working great. :D
One thing that I have noticed about the Davis Airlink - Using it inside, my AQI will frequently be close to 0 or actually 0. So, I have edited the >0 to >=0 to avoid the NA. Not sure there is a good solution to 0 AQI vs offline.
Also, Mobile (Iphone) viewing issue again. Adding the AQI icon leaves no space for the Almanac in Portrait mode, but the Almanac is also missing in Landscape mode.
Portrait:
Landscape:
Best wishes,
ok chuck I have made change just pushed but unfortunately in mobile view there is going to be a compromise just so many different end user configurations to cater for some have everything from air quality,webcam etc some have only a limited standard setup without indoor and so on so in mobile layout for the toolbar at the bottom there is a compromise ...so in mobile view the setup menu disappears as I cant imagine too many set up the template on phone device first time ...
Yes, it is becoming crowded. Removing the setup in Portrait mode is an excellent idea. :idea: I doubt anyone would use it.
Just tested and every thing is fine. :D
yes multiple Air Quality sensors brought some brainstorming :-) get there sooner or later ... sit back and see how it goes .
garybridge
Post by garybridge »
Thanks Brian,
That sorted it!
Just another question... Why would someone want 2 different air quality monitors that are measuring the same thing... surely to be of any use in a comparison you need a 3rd as a control?
Gary Bridge MIET, MIPS.
Hi Gary,
There are a number of users that have one Air Quality Device outside and one inside. So, two different environments.
Best wishes,
garybridge
prestwickwx wrote: Sun Nov 08, 2020 8:59 pm Hi Gary,
Best wishes,
Ahh....
So what would happen if they had a PA indoor and Outdoor?
:D :shock: :D
jasonmfarrow
Post by jasonmfarrow »
Brian, I'm using Aurora and Airlink and it's providing data.
I have not updated my NanoSD to version 5.0, yet all appears to be working in Aurora. If I do update NanoSD to v5.0 will it break the v9.34 of your template which I still have running?
Jason
meteolive57290
Post by meteolive57290 »
hello
:?: i have updated 9.34 to Aurora (> Upgrade.zip file)
i installed my AirLink sensor yesterday >> additional weather station with its own IP for use MeteoBridge Pro
but I can't get the block to work on my dashboard ?
http://seremange-meteolive.franceserv.com/pws/index.php
did I miss something in the setup ? thank you in advance
BR
jasonmfarrow wrote: Tue Nov 10, 2020 2:20 pm Brian, I'm using Aurora and Airlink and it's providing data.
Hi Jason,
I think the only thing you are missing is the 24 hour averages. You don't have to have version 5, but you will need to reboot to get the new API values for the Davis 24 hr averages.
meteolive57290 wrote: Tue Nov 10, 2020 3:18 pm hello
BR
Did you map your Airlink sensors after you setup the Airlink as a 2nd station?
The new chart format looks great :D
@Jason shouldn't change anything I am aware of just a reboot without a firmware upgrade should just pick up new api
@chuck all charts got finally finished far more easier to accomplish without considering languages..there was a lot of chart files updated so might be worth checking you got them all..
