meteolive57290
Post by meteolive57290 »
prestwickwx wrote: Tue Nov 10, 2020 3:52 pm Did you map your Airlink sensors after you setup the Airlink as a 2nd station?
thank you for your reply
:?: in the setup of my MB Pro, no mapping ! just registered the AirLink ... I saw the configurations in the "mapping" tab i suppose that the operations are as follows: I select in the menu pulling out the sensor and I associate the corresponding "mapping" command?
sorry but i wouldn't want to do a wrong manipulation in this setup
Yes. Here is my mapping for the Airlink Station:
weatherist34 wrote: Tue Nov 10, 2020 4:58 pm @Jason shouldn't change anything I am aware of just a reboot without a firmware upgrade should just pick up new api
@chuck all charts got finally finished far more easier to accomplish without considering languages..there was a lot of chart files updated so might be worth checking you got them all..
Yes. One language saves many headaches/ :shock:
I uploaded all of the .php files in the weathe34rcharts directory, so I think I have them all.
meteolive57290
prestwickwx wrote: Tue Nov 10, 2020 6:14 pm Yes. Here is my mapping for the Airlink Station:
thnx +1 solved good continuation Regards :wink:
Glad it worked!
Take care,
rzelle-K1TTC
Post by rzelle-K1TTC »
Brian & Chuck,
I've been watching the forum but very busy with other thing in life .. :-) Hope all are healthy and staying safe. All is well here.
I removed my site from public access for now until I can sort out isolating the server from other parts of my network.
Brian, I accepted your invite for access to Aurora on Github and have reconfigured my Github app for access to it. I've moved to Aurora and it is Really Looking Great! on all my devices.
..73s
..Ron
Hi Ron,
Glad to hear you are well. I noticed that your site was down and wondered what happened.
Brian has been busy with the new version. :D
Take care,
rzelle-K1TTC wrote: Wed Nov 11, 2020 1:33 am Brian & Chuck,
..73s
..Ron
hello Ron glad all is well , yes i was able to design it as I envisioned months ago and removal of languages in this version proved my thoughts right on how easy it would be to design around as envisioned.I follow or visit a site regularly called Dribbble whilst it doesnt offer any ready made code or css design elements for websites its mostly graphical design ideas stuff , I just watch the trends on there and try to put those design ideas into css and thats what your seeing now. so enjoy the template and either way Github or using the now trusted simple update file release will always bring you upto date if you miss updates or not around for various reasons.
todo is only IFTTT implementation where the template will interact with smart devices when IFTTT is installed .
@all
using the simple update file is trouble free for following updates it really is , its proven overtime to be reliable as I have seen the most inexperienced users i dont mean that in any detrimental way but they are able to just follow updates painlessly as it requires no knowledge of coding or requires any hard coding just use the internal update screen in the bottom of the setup screen.
for those who are somewhat disappointed about dropping languages, I am truly sorry but that was or has been on the cards for a long time so please dont bother sending me those socially inept emails they go straight in the bin and i dont reply .
Ecowitt users dont waste your time firing off at me it just falls on deaf ears and I have continuously advised or recommend to take a look at wim van de kuil variation of my original 2017 work to help him or find something suited to your hardware configuration etc...
Hope all is well. Just uploaded the latest and I noticed a change in the font size of some of the values.
Best wishes,
rzelle-K1TTC
Hi Chuck,
Looks like Brian fixed the font issue. As part of you signature how are you display the little weather status icon above your signature?
BTW ... My site is back online now
73s
.. Ron
Seeing this on IOS - IPhone and IPad this morning. Fine on desktop browsers:
Strange?
rzelle-K1TTC wrote: Thu Nov 12, 2020 1:47 am Hi Chuck,
73s
.. Ron
Hi Ron,
You can add an Avatar under the User Control Panel > Profile area of the board.
Glad to see you are back.
Take care,
rzelle-K1TTC
Good Morning Chuck,
I'm not seeing that on my IOS devices in Safari or Firefox I just applied the latest update as well.
Thanks, I'm feeling a bit more confident about my site server's security now that I made the changes.
.. Ron
prestwickwx wrote: Thu Nov 12, 2020 2:17 pm Hi Brian,
Strange?
tried replicating locally but cant can you provide me a setup screen password which you can change at anytime so i can set up locally to be identical.but nothing changed as i can see in that module..
chuck is that fresh install ? settings or timezones all look to be from a default install.. settings
