It must have been a glitch with a file. I re-uploaded all the files in root directory and that fixed it . It was odd because the yellow line would stay even if I changed the module, and it only showed up on the IOS devices - several Iphones and Ipads. I cleared the cache in the browsers, but it didn't help.
I finally figured out what is causing it. It has something to do with the Latitude and Longitude. It does not seem to like my negative Longitude number. If I change it the "yellow tail goes away". Not sure why - just on IOS.
good morning chuck , i spent some time last trying to reproduce this on IOS devices iphone,5,6,7,8,X , iPad mini,air2,Pro and just couldnt , only when i visited your site was it apparent.the lat lon again doesnt make sense has no changes to how that is handled but i will ,take a look today at that but as per email i went through many user sites i have access too and wasnt able to reproduce it .thats the hard part not being able to replicate it locally . last resort is do a fresh install but backing up the weather34 charts folder beforehand.im truly stumped on this one..
ha solved i had similar to this the other day with a guy from australia ... there was a hidden space in the timezone or lat lon i simply deleted the America/New_York and retyped it dont think this was the cause , i deleted the lat lon then retyped it using a google lat lon in .now it works , if i put your original lat lon in it the yellow bar comes back so is it something specific to the length of day .i will look deeper into this .
now looking deeper i see a unique css string related to IOS devices -webkit-overflow-scrolling:touch: so I removed that and updated the css files on github and update file , i actually did read it was advised not to use and forgot to remove it. that was a new addition and its only related to IOS touch devices..so hopefully that will resolve that.please try your original lat lon again after updating .also added grahams request to identify purple air in charts..
have a great day ...
no idea something at mediafire , correct download worked for me just now .thats an old client from the past ..there maybe more sitting on there ..try again ?
weatherist34 wrote: Fri Nov 13, 2020 7:14 am
Just updated and changed the Lat/Long back and everything is fine. Hard to believe that a slight change in Longitude made the difference. I actually uploaded the entire template (new install) to a new directory, yesterday. I went through each of my settings to see which one was causing the problem.
ok chuck no worries id remembered i added the css string on monday when i was playing catchup with various new css strings being released in browser support and i guess for whatever reasons that was causing the overflow with your lat lon..has for the test should get results this evening ,im not showing any symptoms neither is my wife but some of her colleagues tested positive this week so its a precaution not just for us but for those around us and hospital is 10 minutes walk from home..
