progress :-)
atlantic21
Post by atlantic21 »
Hi Brian that's looking great
Richard
progress now to check how it works in non metric/uk metrics etc :-)
This will be a nice addition' :D
ok metrics theoretically work :-) I say theoretically has you never know ...
push to GitHub tomorrow and release later in the week..
had to use wider charts to make the day periods readable and somewhat aligned..
Good morning I have pushed the brand new Forecast page to GITHUB and released via the simple update file . requires no setup and new files contained in a new folder for easy management of adding additional data in future/fixes update releases .
you can access original forecast pop ups via the icons in the footer.
it is mobile/tablet/desktop friendly ..currently is in only dark mode and light mode will come in a future update.
atlantic21
Brian am unable to do the the simple update file via the link
simple update.png (214.59 KiB) Viewed 4581 times
hmmm I think mike(Xray77) reported something like this earlier in the week, the file is there guess just keep trying unfortunately ..perhaps maintenance at media fire ? really dont know ...
woolfg
Post by woolfg »
Hi Brian
Just ran latest update and some AQ chart data is missing - will it populate tomorrow ?
Also applies to 2020 charts http://ringwoodweather.ddns.net/Aurora/ ... s-year.php
Graham
did you do a backup ?? if not then oh dear :-(
woolfg
Post by woolfg »
Hi Brian
I havent needed to do a backup before running the update but I do have one
What files do I need to upload again
Graham
always do a backup thats why i included the option for safe keeping and if things go wrong.. just need the 2020.csv file and the 2020 folder just upload via whatever method you use..
ive double check this update and i cant see why this happened, your not alone my inbox has got a few . sorry i dont have an answer , im curious if download was corrupt at the moment im guessing..
think ill have to find a good download hosted solution obviously mediafire having some teething issues last few days..
so please always do a back up it only takes a second todo with one click..
for reference it only takes a click to perform a backup. it will date your file .literally one click and job done ..be safe things can always mistakenly go wrong . Be safe Back up prior to applying updates.
xray77
Post by xray77 »
Good Morning at all here,
I can download the latest update from MediaFire without any problems.
The update contains the complete weather34Charts-folder including the year folders and the 2020.csv file..., should that be the correct? This would overwrite the own archive files during the automatic update...
I only noticed this because I always let the zip be discovered on my computer to have a look at it before I do an update. :wink:
best regards and stay healthy!
Mike
Hello your a wise man :-) but Im not seeing the same locally so Im at a loss here on what is going on.. the update file does not contain any year files/ month files so Im still trying fathom this out as I cant reproduce the same error or anything to remove those files . please download current update file and check because I cant see anything related to csv files in it .
ive also added an awareness to use regular backups for safe keeping and when things like this happen ..
bottom of setup screen
