xray77
Post by xray77 »
Would it be possible to remove the thick blue permanent scrollbars after updating the css-files (console-dark.css, console-light.css) after the 08.11.20?
Bildschirmfoto 2020-11-15 um 12.50.33.png (288.72 KiB) Viewed 4326 times
I like to manually enlarge the console window a little on my screen, because it does not fill my screen in original size. Until November 8th, the (narrow and grey) scrollbars were only visible for a short time and then disappeared again automatically. Now they are permanently there and even wider and light blue.
It would be nice, if this could return to the status from 08.11.20.
Best regards
Mike
browser ? device ? more stuff i cant see locally driving me nuts ..
xray77
Post by xray77 »
weatherist34 wrote: Sun Nov 15, 2020 1:52 pm Hello your a wise man :-)
Here a screenshot from last update-unzipped-file..
the 2020.csv is also included.
The hint is probably a good idea!
best regards
Mike
Bildschirmfoto 2020-11-15 um 13.03.51.png (121.86 KiB) Viewed 4325 times
xray77
Post by xray77 »
weatherist34 wrote: Sun Nov 15, 2020 2:06 pm browser ? device ? more stuff i cant see locally driving me nuts ..
Safari Version 14.0.1 (15610.2.11.51.10, 15610) macOS Catalina.
In the css-versions before the Nov/08/2020 the scrollbars are grey and goes automatically away after a short time..
Ok, in Firefox 79.0 (64-Bit) the scrollbars are normal and disappears after a short time, seems to be a problem with Safari, mmh. it seem's so I must change my preferred browser from Safari to Firefox.. :?
im trying understand .. I use Safari as default browser I dont see scroll bars unless I use the Zoom function or make the browser window smaller in height .Are you on a later release of Safari browser i.e very recent update in Safari brought issues with overflow scrolling very apparent on latest IOS release 14.2 . so are you using the zoom function in the browser ..
Ive just applied this to the update basically means Safari won't display scroll bars but will retain functionality of scrolling up and down, left right .
scrollbar-width: 2px;
scrollbar-color: var(--blue) var(--border-dark)
::-webkit-scrollbar {
display: none;
::-webkit-scrollbar-track {
background: var(--border-dark)
::-webkit-scrollbar-thumb {
background-color: var(--blue)
in zip file I dont have those files so Im baffled once again . the weather34charts folder only contains PHP files.
so I dont know ..as above baffled
xray77
Post by xray77 »
weatherist34 wrote: Sun Nov 15, 2020 2:28 pm im trying understand .. I use Safari as default browser I dont see scroll bars unless I use the Zoom function or make the browser window smaller in height .
Yes, in original-size no scrollbars appear but the console-screen don't fit my display,
but no hurry, have moved my w34-tabs to firefox which is operate such as expected if zoomed.. :)
If I have time, I will check my two css-files for the entries you mentioned...
It is crazy, that the update zip-file of mediaFire contains all subfolders, but you can't see them.....
I also have no explanation for this, it is just strange. But this explains why some archive data got lost after the update...
Best Regards
Mike
garybridge
Post by garybridge »
Forecast page is Great Brian
Just checking if the the spelling of temperature is a comment on your mood? :)
Gary Bridge MIET, MIPS.
ok im completely baffled.. tell me what you see in this update file
https://www.mediafire.com/file/rus6ew4r ... 0.zip/file
because if i download it unzip it i dont see any year folders or csv files inside the weather34charts folder ..i need a beer or two :?
The new Forecast page is a nice addition and looks great! :D For "fine tuning" I do notice that the Screen size of the Forecast page is slightly longer than the main page. So, if the main page is setup zoomed for maximum screen size, the Forecast page footer will run off the bottom, slightly, when opened.
Not a big deal. The only reason I spotted it is because my main WX viewing computer (23" touchscreen) is zoomed to use the entire screen.
Also, I checked your Weather34 update file and it looks fine, to me. No data files in the Charts folder.
Take care,
(*Aurora Update File for 15th November)
* Correct Temperature Typo Ref Graham(4:12pm)
* CSS overflow scrollbar when zooming hidden(3:35pm)
* Increased Awareness of performing backup in setup screen(2:45pm)
* Adds wind conversion for ms to new Forecast page(2:10pm)
* Adds wind conversion for KTS to new Forecast page(11:55am)
* Adds brand new Forecast page with charts(09:20am)
* Fix IOS sun anomaly ref Chuck
* Adds Purple Air Charts description Ref Graham
see ya all !
Forecast Page length fixed :D
Best wishes,
no problem ...more updates today than Ive had hot dinners :-) (English humor dont worry)
* Reduce forecast height for small resolutions/ratios ref chuck(4:38pm)
* Correct Temperature Typo Ref Gary(4:12pm)
garybridge wrote: Sun Nov 15, 2020 3:02 pm Forecast page is Great Brian
mood is sound just normal after releasing something new , only way to get it right is throw it out there and sit back and wait ..its like fishing :D ... thanks corrected..
xray77
Post by xray77 »
I don't know why..
The actual download-file on mediaFire is shrinked against the file from the morning..
My file size in the morning:
Bildschirmfoto 2020-11-15 um 16.40.14.png (27.21 KiB) Viewed 4284 times
file size with your link posted:
Bildschirmfoto 2020-11-15 um 16.39.58.png (33.91 KiB) Viewed 4284 times
the year-folder's and the 2020-csv-file are gone..
crazy..
Thank you, the big blue scrollbars at zooming on safari also gone.. :-)
regards
Mike
woolfg
Post by woolfg »
Hi Brian
Just a couple of observations/questions
a) Is there a reason why the Davis AQ PM 10 displays to 2 decimal places when Purple Air is one
b) there isnt a 24hr average for the either the Davis or Purple Air PM10
Its not a problem I was just interested why
Graham
