no reason just preoccupied..
for Davis i have these to implement day max and day avg just not got around to it.they have been available for a couple of weeks now .
from the API list
180 [air2pm-act:--] * Davis Air Quality PM1 New October 2020
181 [air1pm-act:--] * Davis Air Quality PM 2.5 New October 2020
182 [air0pm-act:--] * Davis Air Quality PM 10 New October 2020
183 [air2pm-davg:—] * Davis Air Quality PM 1 day average New November 2020
184 [air1pm-davg:—] * Davis Air Quality PM 2.5 day average New November 2020
185 [air0pm-davg:—] * Davis Air Quality PM 10 day average New November 2020
186 [air1pm-dmax:--] * Davis Air Quality PM 2.5 day max New November 2020
187 [air0pm-dmax:--] * Davis Air Quality PM 10 day max New November 2020
down the road there will be month max , year max added and these can be added to almanac type screen just need some thought on how to make it all fit in with design..
Purple Air if the pm10 24hour/ day average is there in the api i can add it on but i would need to check your API output first.
@Graham ok added on 24 hour average for Davis PM10 also added day max values see screenshot below .via simple update(yes double checked for year/month files are not present in the update )
corrected the rounding of PM10 example 10.21 is now 10.2
Purple Air API I dont see a 24 hour average in rthe API for the PM10 unless its there but the reference I use from there documentation is below again I see no reference for 24 hour Average for PM10
"Stats": // Statistics for PM2.5
\"v\":1.07, // Real time or current PM2.5 Value
\"v1\":1.3988595758168765, // Short term (10 minute average)
\"v2\":10.938131480857114, // 30 minute average
\"v3\":15.028685608345926, // 1 hour average
\"v4\":6.290537580116773, // 6 hour average
\"v5\":1.8393146177050788, // 24 hour average
\"v6\":0.27522764912064507, // One week average
\"pm\":1.07, // Real time or current PM2.5 Value
\"lastModified\":1490309930933, // Last modified time stamp for calculated average statistics
\"timeSinceModified\":69290 // Time between last two readings in milliseconds
Screenshot at Nov 15 20-10-23.jpg (88.05 KiB) Viewed 4659 times
woolfg
Post by woolfg »
Brian
What can I say - you are a star !!
Graham
yeah thats what my wife sez :-) also changed the thunderstorm forecast to wind direction scatter plot in the charts . think the thunderstorm and snowfall Im going to have to come up with a seasonal option..no point in snow during summer but thunder is more apparent during the warmer months though we do get snow thunder here .. anyway thats it for today ...
woolfg
Post by woolfg »
Hi Brian
Before you open that bottle of wine
http://ringwoodweather.ddns.net/Aurora/ ... recast.php
Graham
woolfg
Post by woolfg »
Brian
Sorted - I had to do a manual update of the forecastcharts folder, for some reason not all the files went over
Anyway you can open that bottle now
Graham
rzelle-K1TTC
Post by rzelle-K1TTC »
The new forecast charts are looking Excellent ..
..73s
Ron
xray77
Post by xray77 »
I suspect that the temperature forecast map is not in phase with the other forecast maps, which go from tonight to Friday. You can also see it in the maximum temperatures, which would therefore always occur at night. Also there seems to be a little font-alignment-problem.. (only in Safari, on firefox it's looking ok).
Best regards and good night,
Mike
Bildschirmfoto 2020-11-15 um 22.47.07.png (278.48 KiB) Viewed 4634 times
xray77
Post by xray77 »
Good Morning,
I was probably too impatient :-) This morning the data's match... Let's wait and see.
Brian: Great work, it look's very nice! :-) :-)
Bildschirmfoto 2020-11-16 um 08.48.48.png (197.55 KiB) Viewed 4623 times
Best regards
Mike
good morning i have made some changes to alignment for day/night phrase , also addressed the anomaly in forecast temp .i have seen this before a year or so ago ..think i have fixed that..note the word think... :shock:
as always do a backup but once again file update was double checked..
i am working on a option to show snow when present in uv position..
have a good day
Screenshot at Nov 16 11-19-04.png (162.36 KiB) Viewed 4615 times
atlantic21
Post by atlantic21 »
Looking to add missing 2 months from beginning of year not sure what the missing tabs are in screen shot
Excel layout.png (5.52 KiB) Viewed 4608 times
this should hep you ..
position 8 will be used eventually for wind direction when I get the chance to do it ..for now it has day average temp but its not actually used in any charts so don't pay too much attention to that just put 1 or some value
*important the wind values are ms default output from meteobridge. the charts script converts them to user choice when displayed .
atlantic21
Brian thanks
a bit more info might be useful for the advantageous amongst us :-) but if you want to understand the use of exporting direct from meteobridge please open up a new thread or discuss in an existing thread , Im not the expert in explaining things clearly.
to me I just do it but I dont know how to put that into a useable "how todo" so please do digest this forum for answers ...
export direct from meteobridge but consider the date must be in the first column of the csv file
[th0temp-dmax:--] [th0temp-dmin:--] [th0dew-dmax:--] [th0dew-dmin:--] [rain0total-daysum:--] [wind0wind-dmax:--] [wind0wind-davg:--]
[th0temp-davg:--][thb0seapress-dmax:--][thb0seapress-dmin:--] [uv0index-dmax:--] [sol0rad-dmax:--] [air2pm-davg:—][air1pm-davg:—]
thank you all for the feedback it is all appreciated not all ideas are feasible but there are alternative ways to implement with some thought, I may not respond immediately or implement something immediately sometimes it takes time to try different approaches and design but sooner or later it gets there.So when a new feature gets released it always takes a few days to polish it off so your feedback was very much appreciated and your PATIENCE.
I will sit down and put together a request to Boris to export the yearly data directly from meteobridge in the format used in the template .This will allow new users to simply be able to use past data stored in meteobridge. Also if things go a bit Pete Tong (means wrong in English cockney slang :D as Im a native Englishman contrary to many thinking Im Turkish ! ...)
the forecast page is now done this came about from a request to have something like a meteogram which Ive seen in the past , however Im not a lover of having all information displayed in one chart it becomes hard to use it for quick viewing .. I like things to be reasonably easy to read and cleanly viewable so this is it how it turned out ...
17-11-2020 update simply adds 3 notifications for awareness of rain, snow,thunderstorm if present in the forecast in the next 5 days.
the notification only appears on entering the page and disappears after 10 seconds it is not going to annoyingly display repeatably if page is left open
