I've changed the port number 95 instead of 80 in the Network setup.
Now I cannot acces to meteohub with HTTP.
By ssh is working, the ping is working, the public folder is available.
Then : Is it possible to change the network setup by command line ?
Is is possible to access via the web but not the port has configured ?
Any idea to restore the value of the port to 80 ?
Thank you
						Port change and now no more main menu available
- YJB
Re:Port change and now no more main menu available
Have you tried to login using:
http://<ip address>:95
Yes and I have error msg "Network port not authorized".
You should still be able to reach it via port 7777, which is Meteohub's fall-back failsafe port for dealing with problems such as this.
Odds are your router doesn't like your port reassignment -- perhaps port 95 is important for other protocols that you're not aware of. (a quick bit of Googling shows that port 95 is assigned to SUPDUP -- am old, beefed up telnet protocol.)
Great it's working !! Thank you
