I even found a vantage meteostick ! , 2 nano another Tplink not including the two downstairs .. so shall I offload them all :-) just kidding but one mans junk is another mans gold !!
WessexWeather
Post by WessexWeather »
You’ve been very helpful Brian. I’ve got this awesome template for my Davis data, and thanks to your previous hard work, and handing it over to Wim, I have my WeatherFlow data on PWS_Template using the realtimeMB.txt template (with tags changed to the WF sensors - eg. [th1!0temp-act:--]).
weather34 (Davis): -
https://wessexweather.net/weather34/index.php
PWS_Dashboard (WeatherFlow): -
https://wessexweather.net/tempest/pwsWD/index.php
All the best,
Simon
no problem FWIW your probably the only person who has acknowledged i gave the foundation and groundwork of his template to him to build upon so many thanks for acknowledging sometimes a little thanks is worth more than the weight of gold..:-) must be a day of philosophical words ..you take care..brian
slrpwr
Post by slrpwr »
This isn't urgent, but could you add RPi as a Meteobridge platform type in the settings?
do you mean rpi svg for setup screen for info screen ? because its the only place its now relevant
thank you for your pm and offer reference shipment of solar sensor its now been sorted ..many thanks
jasonmfarrow
Post by jasonmfarrow »
WessexWeather wrote: Thu Jan 21, 2021 2:58 pm weather34 (Davis): -
Hi Simon, I like the overlay format you use on your webcam. Would you care to share the overlay code from your meteobridge?
Jason
slrpwr
Post by slrpwr »
weatherist34 wrote: Thu Jan 21, 2021 4:20 pm do you mean rpi svg for setup screen for info screen ? because its the only place its now relevant
Yes, that upsets my OCD. :D
Great!
slrpwr wrote: Thu Jan 21, 2021 5:00 pm
Great!
ok just added the option via the simple update.
* Adds Raspberry PI option to setup Ref Rick (6:44pm).
* Correct Lunar phrase ref @wessexweather (2:06pm).
* Increase relatives indicator bars by 1px (2:06pm).
* Fix WF(inc..Chuck module)lightning indicators colors (2:06pm).
* Fix VOC(Purple Air) indicator colors + phrases(2:06pm).
slrpwr
Post by slrpwr »
weatherist34 wrote: Thu Jan 21, 2021 5:46 pm * Adds Raspberry PI option to setup Ref Rick (6:44pm).
Thanks. Very soothing! 8)
slrpwr
Post by slrpwr »
I searched, but didn't find a result. Has there been a request for a large font, current conditions display suitable for a cheap tablet? Something that could be read from across the room.
I visualize this as a persistent display showing key current conditions (in/out temp, humidity, precipitation, a wind rose and maybe Solar/UV). The user could tap on the display and go to the main Weather34 page, or the weather34-tv page to interact with details. After some period of inactivity, go back to the current conditions page.
Anyway, if that's something that interests you, I know I'd use it not only to replace my Davis Vantage Pro2 display, but also give my tired, old tablets something to do.
weatherist34 wrote: Thu Jan 21, 2021 11:30 am good morning reaching out to anyone in the USA .
unfortunately my solar sensor has a cracked diffuser, caused by local crows constantly pecking at with there beaks , sounds bizarre but over the last few months ive noticed them perched around it and constantly pecking at either the uv sensor or the solar sensor , on inspection this morning i see it is now completely cracked and chipped ! whilst is still works its only a matter of time before condensation or water intake will damage the internals .
so my usual uk source is out of stock and I need to find a way to order one from the USA most wont ship to turkey or have the option.
So reaching out here if any USA user would order one sent to there home and then send it on to me . I will cover all shipping costs and resolve import duty my end . If you can help contact me and only if you accept International bank transfers , i will simply transfer the money prior to you placing order. only inconvenience is that you would need to arrange shipment here to turkey via UPS , DHL please do not use USPS they are pretty dismal in international deliveries due to pandemic, i have a one of these sitting in miami florida since december https://www.iqair.com/us/air-quality-mo ... visual-pro it was shipped by USPS and hasnt moved for weeks . So i got refund finally last night..
also has anyone experience of using scientific sales as I would like to have this ordered https://www.scientificsales.com/6450-So ... p/6450.htm
anyway thanks in advance if anyone can help if not just have to source it somewhere else in europe..brian
Please disregard its now been sorted and on its way..
Just read this. Glad to hear you have a Sensor on the way.
atlantic21
Post by atlantic21 »
Hi Brian when i look at the chats for month and year have noticed the rain is not updating for the previous day and pressure value is odd
https://www.ilfracombeweather.net/console/index.php
have checked meteobridge and info is there
Rain for 21-01-2021.png (80.91 KiB) Viewed 4796 times
see January csv file
January 2021.png (44.68 KiB) Viewed 4796 times
pressure .png (8.49 KiB) Viewed 4796 times
Thanks atlantic21 ( Richard )
richard good morning are you running the new end of day file ? double check the new procedure is running this file
weather34-chart-end-of-day.php at 00:15 to me looks like your running at 00:15 to the old file.
see https://weather34.com/homeweatherstation/
i did spot this on your site a couple of days ago and could see it wasnt using the new file , so sorry i just got sidetracked and forgot to make you aware..brian
Good morning Chuck
unfortunately it didnt work the kind mans account kept asking for a swift code , ive hit this brick wall before so its more stress or inconvenience than its worth him todo so , i decided to wait till I can source one somewhere else or just wait till the pandemic subsides . chasing bank IBAN numbers and swift codes can be daunting for those unfamiliar.
ill just keep looking at amazon and wait for a option to deliver to turkey appear.we are used to this ..
slrpwr wrote: Thu Jan 21, 2021 7:41 pm I searched, but didn't find a result. Has there been a request for a large font, current conditions display suitable for a cheap tablet? Something that could be read from across the room.
i use a few cheap OEM 10” android non branded no thrills $40 tablets and a smart tv occasionally, i prefer the 55” smart tv view i get your point about a large font but needs some thought in how to make it intuitive and UI friendly without it becoming a mess in design and importantly manageable going forward .really trying to keep it manageable so the enthusiasm remains when it gets tedious and messy then my enthusiasm wanes quickly.
