atlantic21
Post by atlantic21 »
Morning Brian i have been running the new end of day file and i have also done a reboot of meteobridge
new end of day.png (70.1 KiB) Viewed 4778 times
Richard
Good morning Richard
your running the old file change the file to weather34-chart-end-of-day.php
your running charts-end-of-day.php which is the old file.
hope that helps ..Brian
new end of day.png (124.59 KiB) Viewed 4773 times
xray77
Post by xray77 »
Hello Brian,
It seems so, I have found a little issue at the wind-max-times who displayed on main-screen:
On Main-Screen windmax-time is 05:07 which is definitively wrong
Bildschirmfoto 2021-01-22 um 08.45.14.png (95.31 KiB) Viewed 4770 times
On extra-info-screen the correct max wind-time is displayed 08:10
Bildschirmfoto 2021-01-22 um 08.45.37.png (168.65 KiB) Viewed 4770 times
The other min/max-times which displayed on main-screen seems to be correct, only the wind-values are affected.
I have observed this not only today, also yesterday...
Maybe you can see if you can verify that with yourself?
Thank you!
best regards and stay healthy
Mike
can you tell me where your MBrealtimeupload.txt is ?
because this https://buedelsdorfwetter.de/Aurora-MKI ... upload.txt out of date 27/12/2020
https://buedelsdorfwetter.de/Aurora/mbr ... upload.txt is even older 29/10/2020
27/12/2020 10:10:58 7.5 22.0 -6.8 12.0 0.0 291.0 0.0 0.0 1025.5 291.0 0 m/s C hPa mm 0.0 1024.8 50.8 1268.8 0.0 21.3 36.0 7.8 1.6 7.5 20201227100638 -2.6 20201227064026 0.0 20201227000006 0.0 20201227000006 1025.5 20201227100344 1020.8 20201227004342 5.0 3668 0.0 3.9 -- 0.9 0.0 213.0 291.0 0.0 18.6 20201214122631 -9.6 20201225154741 -2.7 20201226205913 28.1 20200902123712 -11.6 20200121192822 0.9 93.0 20201227085826 48.0 20201227100230 1.4 20201227092628 -4.4 20201227064026 6.9 56.0 -1.4 21.0 36 0.0 0.0 -- -- -- -- -- -- 429.0 6259 7.4 20201226144203 -3.7 20201226071030 22.1 20201214143427 -3.7 20201226071030 35.6 20200903144952 -3.7 20201226071030 4.0 20201226103559 16.8 20201214153031 22.2 20200803224725 0.0 50.8 20201201000047 1268.8 20200413084858 429.0 20201227095052 650.0 20201226115203 886.0 20201217125218 1415.0 20200709133210 20201227094736 2.0 20201226114847 2.8 20201206120458 11.8 20200611125909 -9.5 20201226004346 0 5.2 20201225123817 38.5 20190528150000 -8.3 20180107060000 28.2 20190810135117 -20.5 20190121110000 28.2 20190905182901 1024.4 20201226093750 1018.6 20201226154645 1029.5 20201219095952 1001.3 20201224205545 1036.7 20200117211540 991.3 20200207005531 1049.1 20141015190000 976.6 20161008130000 2372.1 -1.3 3 93.8 09:56 15:25 04:59 0.0 98.0 20201214050604 32.0 20201222152205 98.0 20201028084233 17.0 20200410154207 91.0 20201226234037 36.0 20201226130835 0.0 0.0 122.6 1103.3 0.1 7.4 1025.5 0.9 0.0 0.0 0.1 0.1 0.1 0.1 0.3 1.0 2.5 276.0 0 0 267.0 46.3 20200902105742 -9.8 20200121075713 _Mostly clear with little temperature change.
xray77
Post by xray77 »
Hello Brian,
My MBrealtimeupload.txt is on
https://buedelsdorfwetter.de/mbconsole/ ... upload.txt
ok found it its the API which is not something I can correct quickly I have sent a recompiled API to Boris just now Ill push an update when he has updated it . many thanks for finding this .
Brian
xray77
Post by xray77 »
Hello Brian,
Ok, you're welcome!
You've doing a great job, many thanks again for it!
Best regards
Mike
atlantic21
Looks like i need to start wearing my glasses :oops:
slrpwr
Post by slrpwr »
weatherist34 wrote: Fri Jan 22, 2021 8:52 am i use a few cheap OEM 10” android non branded no thrills $40 tablets and a smart tv occasionally, i prefer the 55” smart tv view i get your point about a large font but needs some thought in how to make it intuitive and UI friendly without it becoming a mess in design and importantly manageable going forward .really trying to keep it manageable so the enthusiasm remains when it gets tedious and messy then my enthusiasm wanes quickly.
I fully understand, so please don't undertake this suggestion if it doesn't work for your roadmap or satisfy your enthusiasm.
Having said that, I had a couple of ideas that might work.
First -- perhaps there could be large font versions of the needed modules (like temperature mod.php). Big temperature text and little else, same module dimensions, so that it could be used in the current template.If we had that, I'd simply create another instance of Weather34 with those modules selected and zoom to a 2x2 grid on the tablet.
Screen Shot 2021-01-22 at 8.32.48 AM copy 4.png (383.17 KiB) Viewed 4729 times
Second -- and I understand if this might make things unmanageable -- would be to have a new 2x3 template for those modules to be placed into.
Screen Shot 2021-01-22 at 8.32.48 AM copy 5.png (426.11 KiB) Viewed 4729 times
Anyway, they're just ideas, so I'm not going to be offended if they never happen.
jasonmfarrow
Post by jasonmfarrow »
slrpwr wrote: Fri Jan 22, 2021 5:15 pm First -- perhaps there could be large font versions of the needed modules (like temperature mod.php). Big temperature text and little else, same module dimensions, so that it could be used in the current template.If we had that, I'd simply create another instance of Weather34 with those modules selected and zoom to a 2x2 grid on the tablet.
I asked a similar question when I was trying to make the template fit on the official Raspberry Pi screen (which is a 7" screen and has 800x400 resolution).
To make this work I pretty much duplicated the entire template and hand-edited each of the modules to remove many items of text and increase the size of the main data in each module. I also had to reduce the size of each grid element to maintain the 3 items across the screen when the templated wanted to re-format it to 2-across (which wasted screen space).
It took a very long time and lots of manually tweaking of the module code and the .CSS files until it looked usable. It's not something I'd want to do again because as soon as I've got it working Brian would add some wonderful innovation and I'd have to re-do all the work (and the .CSS!!)
It's not worth it unless you like a lot of work. Just get a screen where you can change the resolution to something just usable (1024x768) which will make the template look big without re-work.
Jason
xray77 wrote: Fri Jan 22, 2021 10:53 am Hello Brian,
Ok, you're welcome!
Best regards
Mike
Mike Boris fixed the API earlier so a meteobridge reboot is required for this FIX .
somehow it was overlooked it had
[wind0avgwind-dmaxtime:—]  should have been [wind0wind-dmaxtime:—] my mistake .. :-(
22nd January 2021
*important reboot meteobridge required
* Fixes Wind day max time ref Mike (8:42pm).
* Important update requires Meteobridge Reboot (8:42pm).
Hi feel free to modify to your liking / preference just beware updates will break the CSS modifications
search for the strings in both CSS files
dark theme
.button-dial-label{font-size:25px;position:relative;z-index:10;left:5px;top:4px;color:var(--body-text-dark)}
light theme
.button-dial-label{font-size:24px;position:relative;z-index:10;text-shadow:var(--text-shadow);color:var(--silver)}
xray77
Post by xray77 »
weatherist34 wrote: Fri Jan 22, 2021 7:49 pm
22nd January 2021
Hello Brian,
This fixed it! Thank you very much and good night,
stay healthy!
Mike
jasonmfarrow
Brian, just looking at the contents of api-build2021-Jan.php while trying to resolve a 0.1C difference in data between the meteobridge and template and I spotted an oddity:
API(30) and API(32) are both using [wind0wind-dmax:--]. Is that deliberate?
Jason
position 30 is not used in livedata.php so it has NO bearing on the template . its marked for change in the api for future but that won't happen for many months or hopefully never. API is complex and so easy to mess up things.please dont ask for API request changes its not gonna happen . you can build your own quite easily by simply modifying the config but thats done at your own risk and again simple updates will overwrite modifications.
see this guy https://meteo.ciucasx3.ro/?lang=ro he spent a lot of time and perhaps weeks modifying template for Vaisala hardware with out meteobridge unfortunately he can not use any simple updates without recompiling everything. he got a lot of things messed up at the beginning but eventually he got 90% working .
see API page https://weather34.com/homeweatherstatio ... 4-api.html
30 [wind0wind-dmax:--] * will change in 2021 at some point
31 [wind0wind-dmaxtime:--]
32 [wind0wind-dmax:--]
