atlantic21
Post by atlantic21 »
Hi Brian have just done the latest update and i have the following problem with my charts they are showing in white where i use dark mode
https://www.ilfracombeweather.net/console/index.php
Hi just run the update should resolve that some files didn't get uploaded there were almost a 100 files unfortunately looks like some didn't get zipped up .apologies..
should resemble below .
atlantic21
No need to apologise appreciate all that you put in to make this all work so well
Ok but if I make a mistake it is only right to apologize ..
This tends to happen when I switch from using my desktop to a laptop the workflow just feels different .
In the update yesterday there were missing files i.e font folder for charts and the reworked moon phase scripts .
so this morning I double checked the update and all seems ok (theoretically :-) )
Its worth noting when running backups is to get into some routine of storing these backups on your desktop environment be it hard drive or a back up drive.Keeping the backups on your server will increase the size of backups each time and as noted in a previous post this can dramatically grind your server to a halt if you have multiple backups already on server because the backup will basically add those to the backup your running . so caution there is required and some form of regular routine deleting of backups on server is best practice though don't forget to keep a copy on your desktop environment.
simple example
Download Update 11th March 2021
* Significant Update (09.:37).
* Adds missing files from previous update file (09.:37).
* Rewrite of moonphase scripts (09.:37).
* Expect API changes at end of March (News).
* API change will render versions 9.34,8.34 broken (News).
* Update File Last Updated 6 Minutes Ago
Bart
Post by Bart »
weatherist34 wrote: Wed Mar 10, 2021 7:17 pm
jasonmfarrow wrote: Wed Mar 10, 2021 5:49 pm I don't think my info loads quite this slowly. ~512 thousand years?
Clearly there's no rush to fix this non-weather related error.
@Bart are you referencing internal version if so its a question for Boris as I have no control or means over anything internal.
Brian
Hello, good morning all.
Brian, can you help me out? Who and where is Boris. :lol: :lol: :shock:
By the way ... in the concept of cleanliness and order that you've pointed to me and all of you now. When updating, the update zip remains on the server. And soThere were 4 on my server, and thus in the backup. It also does not belong in the concept of tidy ..... I thought now that I am cleaning up after you good advice ....
Have a nice day.
Bart
Bart wrote: Thu Mar 11, 2021 11:29 am
Brian
Have a nice day.
Bart
no problem glad to be of help, just make sure you run the update from the 11th March it contains some missing files from last update yesterday..have a good day..
ps Boris without him we would not have a platform to develop and design around i just make it look pretty :D
Bart
Post by Bart »
I did update yesterday and this morning again, the march 11th zip. But it keeps telling that it is "version Aurora MKII 10th March 2021
Stable Release". :roll: :roll: :?:
Bart wrote: Thu Mar 11, 2021 1:00 pm I did update yesterday and this morning again, the march 11th zip. But it keeps telling that it is "version Aurora MKII 10th March 2021
try downloading again and run it . your site is not reflecting the updates that were missed from yesterday.
Bart
Post by Bart »
Deleted de update directory on the server and the zip. Downloaded and installed the zip. Deleted history. Restart my browser.....No change
I have looked into the server and there are no files present with a date of today (with the exception of the ones you expect it from). Looked into the update zip of today (11the) and there are files made today at 12:01, but on the server with a timestamp of yesterday. That would be correct because I update yesterday the then present update of the 10th
hmmm local server issue ? should it not have todays date on updated files if you applied todays update ?
* Aligns colors better to windspeed related modules (15:38).
* Significant Update (09:37).
* Adds missing files from previous update file (09:37).
* Rewrite of moonphase scripts (09:37).
Aurora-MKII-update (1.08mb)
* Update File Last Updated About 2 Hours Ago
garybridge
Post by garybridge »
weatherist34 wrote: Thu Mar 11, 2021 4:10 pm hmmm local server issue ? should it not have todays date on updated files if you applied todays update ?
@Bart may have a problem that I have seen before, when the update file is uploaded to the server and then extracted via the normal means, it creates a folder in the root with the name of the zip file as its name as if you had unzipped it with a "unzip here " command
In the folder are all the files and folders unzipped...
I think it might be due to permissions, So when I upload via FileZila I give the zip file 777 permissions before I run the update.
Of course I might be speaking Manchestur Bollox...
Gary Bridge MIET, MIPS.
Bart
Post by Bart »
No sorry, did work. The update of yesterday had the same permission and did its job. The one of this morning had also permission 644. `I changed it and the files did not get an update. Can I do it manually? I don't think it was Manchester b... but worth a try. At least to an Amsterdam believer...
garybridge
garybridge wrote: Thu Mar 11, 2021 4:29 pm
H'mm I was talking bAllcocks
I've just tried it as per the previous update and when I look I have a new folder under public_html called Aurora-MKII-simple-update-11-03-2021
I really wish I knew what I'm doing wrong sometimes it works sometimes it doesn't...
garybridge
Bart wrote: Thu Mar 11, 2021 5:21 pm No sorry, did work. The update of yesterday had the same permission and did its job. The one of this morning had also permission 644. `I changed it and the files did not get an update. Can I do it manually? I don't think it was Manchester b... but worth a try. At least to an Amsterdam believer...
I can't get it to work either Bart, so have updated manually
What I did was
Unzip update file to PC
Open it you will see two folders
Copy those two over the folders on your webserver
Then do the same with all the remaining files
I'm not suggesting you do this but it worked for me
Gary
Bart
Post by Bart »
Thanks Gary,
Ik did copy the files this way. The date of the files on the server changed. So that's ok. But the date in the window "Weather34" (where you seecheck for updates) is still "Aurora MKII 10th March 2021 Stable Release". Maybe someone can see if my site is up-to-date now? :shock: :? :lol:
Bart
