Hi , I have big problem with my Meteohub v.4.1d (ALIX.1D)
I don't understand the question ...
This is my meteohub log :
logger (25.02.2009 20:13:14): data logger started.
logger (25.02.2009 20:13:14): connect station 0 (TE-923).
logger (25.02.2009 20:13:15): station 0 (TE-923), hardware version 4.
wmr928fulleval(25.02.2009 20:15:01): recomputation of weather data started.
wmr928fulleval(25.02.2009 20:18:18): recomputation of weather data finished: 374681 records processed
in 197 seconds (1901 records per second)
// TESTING ....
logger (25.02.2009 21:40:15): data logger started.
logger (25.02.2009 21:40:15): connect station 0 (TE-923).
logger (25.02.2009 21:40:16): station 0 (TE-923), hardware version 4.
wmr928fulleval(25.02.2009 21:45:01): recomputation of weather data started.
wmr928fulleval(25.02.2009 21:49:05): recomputation of weather data finished: 375211 records processed
in 243 seconds (1544 records per second)
// TESTING ....
logger (25.02.2009 21:54:07): data logger started.
logger (25.02.2009 21:54:07): connect station 0 (TE-923).
logger (25.02.2009 21:54:08): station 0 (TE-923), hardware version 4.
wmr928fulleval(25.02.2009 21:55:01): recomputation of weather data started.
wmr928fulleval(25.02.2009 21:58:48): recomputation of weather data finished: 375271 records processed
in 227 seconds (1653 records per second)
logger (01.03.2009 05:28:49): data logger started.
logger (01.03.2009 05:28:50): connect station 0 (TE-923).
logger (01.03.2009 05:28:51): station 0 (TE-923), hardware version 4.
wmr928fulleval(01.03.2009 05:30:02): recomputation of weather data started.
wmr928fulleval(01.03.2009 05:33:53): recomputation of weather data finished: 403091 records processed
in 230 seconds (1752 records per second)
// TESTING ....
logger (02.03.2009 17:52:35): data logger started.
logger (02.03.2009 17:52:36): connect station 0 (TE-923).
logger (02.03.2009 17:52:37): station 0 (TE-923), hardware version 4.
// TESTING ....
logger (02.03.2009 18:27:43): data logger started.
logger (02.03.2009 18:27:44): connect station 0 (TE-923).
logger (02.03.2009 18:27:45): station 0 (TE-923), hardware version 4.
// AUTO RESET FROM SOFTWARE ... EVERY DAY AT 00:04 ...
logger (03.03.2009 00:06:19): data logger started.
logger (03.03.2009 00:06:20): connect station 0 (TE-923).
logger (03.03.2009 00:06:21): station 0 (TE-923), hardware version 4.
logger (03.03.2009 16:45:25): data logger started.
logger (03.03.2009 16:45:26): connect station 0 (TE-923).
logger (03.03.2009 16:45:27): station 0 (TE-923), hardware version 4.
wmr928fulleval(03.03.2009 16:50:01): recomputation of weather data started.
wmr928fulleval(03.03.2009 16:53:56): recomputation of weather data finished: 421735 records processed
in 235 seconds (1794 records per second)
logger (04.03.2009 00:04:05): parent process received terminate signal (15).
logger (04.03.2009 00:04:05): child process received terminate signal (15).
logger (04.03.2009 00:06:18): data logger started.
logger (04.03.2009 00:06:19): connect station 0 (TE-923).
logger (04.03.2009 00:06:20): station 0 (TE-923), hardware version 4.
logger (05.03.2009 00:04:06): parent process received terminate signal (15).
logger (05.03.2009 00:04:06): child process received terminate signal (15).
logger (05.03.2009 00:06:19): data logger started.
logger (05.03.2009 00:06:20): connect station 0 (TE-923).
logger (05.03.2009 00:06:21): station 0 (TE-923), hardware version 4.
// START PROBLEM
logger (05.03.2009 07:57:48): error while doing bind (port 5500): Address already in use
logger (05.03.2009 07:58:18): error while doing bind (port 5500): Address already in use
logger (05.03.2009 10:29:18): error while doing bind (port 5500): Address already in use
logger (05.03.2009 10:29:48): error while doing bind (port 5500): Address already in use
// BRUTAL RESET .... POWER OFF & ON ...
logger (05.03.2009 19:08:06): data logger started.
logger (05.03.2009 19:08:07): connect station 0 (TE-923).
logger (05.03.2009 19:08:08): station 0 (TE-923), hardware version 4.
wmr928fulleval(05.03.2009 19:10:01): recomputation of weather data started.
wmr928fulleval(05.03.2009 19:13:59): recomputation of weather data finished: 431635 records processed
in 238 seconds (1813 records per second)
logger (05.03.2009 19:51:44): no signal from station 0 (TE-923) for 150 seconds, station restarted.
logger (05.03.2009 19:54:11): error while doing bind (port 5500): Address already in use
logger (05.03.2009 20:02:11): error while doing bind (port 5500): Address already in use
logger (05.03.2009 20:02:41): error while doing bind (port 5500): Address already in use
logger (05.03.2009 20:03:11): error while doing bind (port 5500): Address already in use
logger (05.03.2009 20:03:41): error while doing bind (port 5500): Address already in use
logger (05.03.2009 20:04:11): data logger started.
logger (05.03.2009 20:04:12): connect station 0 (TE-923).
logger (05.03.2009 20:04:13): station 0 (TE-923), hardware version 4.
logger (06.03.2009 00:04:06): parent process received terminate signal (15).
logger (06.03.2009 00:04:06): child process received terminate signal (15).
logger (06.03.2009 00:04:07): disconnect station 0 (TE-923).
logger (06.03.2009 00:04:07): data logging stopped.
logger (06.03.2009 00:06:19): data logger started.
logger (06.03.2009 00:06:20): connect station 0 (TE-923).
logger (06.03.2009 00:06:21): station 0 (TE-923), hardware version 4.
logger (06.03.2009 02:42:05): error while doing bind (port 5500): Address already in use
logger (06.03.2009 02:42:35): error while doing bind (port 5500): Address already in use
logger (06.03.2009 02:43:05): error while doing bind (port 5500): Address already in use
logger (06.03.2009 15:20:11): error while doing bind (port 5500): Address already in use
logger (06.03.2009 15:20:41): error while doing bind (port 5500): Address already in use
logger (06.03.2009 15:21:11): error while doing bind (port 5500): Address already in use
logger (06.03.2009 15:21:41): data logger started.
logger (06.03.2009 15:21:42): connect station 0 (TE-923).
logger (06.03.2009 15:21:43): station 0 (TE-923), hardware version 4.
logger (06.03.2009 18:14:39): no signal from station 0 (TE-923) for 150 seconds, station restarted.
logger (06.03.2009 18:17:08): error while doing bind (port 5500): Address already in use
logger (06.03.2009 18:17:38): error while doing bind (port 5500): Address already in use
logger (06.03.2009 18:18:08): error while doing bind (port 5500): Address already in use
logger (06.03.2009 20:25:08): error while doing bind (port 5500): Address already in use
logger (06.03.2009 20:25:38): error while doing bind (port 5500): Address already in use
logger (06.03.2009 20:26:08): error while doing bind (port 5500): Address already in use
// SOFTWARE RESET
logger (06.03.2009 20:26:34): parent process received terminate signal (15).
logger (06.03.2009 20:27:35): data logger started.
logger (06.03.2009 20:27:36): connect station 0 (TE-923).
logger (06.03.2009 20:27:37): station 0 (TE-923), hardware version 4.
Any idea ?
Is possible battery low power ?
Is possible USB cable ?
My Irox maintains the correct weather data in memory, perfectly readable by WSWIN.
Regards Stefano
Error while doing bind (port 5500): Address already in use
Re:Error while doing bind (port 5500): Address already in us
Should be solved with newest update 4.1e
Great ....
Thank's
Stefano
Thank's
Stefano
