hi ron
you need to look in the services of meteobridge too see if weather34-chart-end-of-day.php is correctly set.
i ran it through the browser and it correctly added expected hi,lo avg data from yesterday as you can see now. also the year charts indicates a gap from 28th april to 4th May so its been like that since the 28th April.so need to look in services screen of meteobridge, check paths etc .
brian
brian
- rzelle-K1TTC
It was the service still set to charts-end-of-day.php. Interesting that it was working up to 4/28 ...
.73s
..Ron
.73s
..Ron
simple update improves menu layout to increase those with lots of custom menu items ,minor design appearance change
Download Update 7th May 2021
* Rework menu layout to improve custom menus (11:03)
I noticed a difference between my menu and the menu in the screenshot. I haven't noticed it before. Why is AirQuality Data not listed as a separate item in my menu. Could it be that I have set something wrong. I have just installed the may 7th update.
good evening BartBart wrote: Sat May 08, 2021 2:00 pm I noticed a difference between my menu and the menu in the screenshot. I haven't noticed it before. Why is AirQuality Data not listed as a separate item in my menu. Could it be that I have set something wrong. I have just installed the may 7th update.
firstly reboot your meteobridge to pickup new api values looking at your average day humidity figure tells me needs a reboot.
you can add a custom option to menu display Air Quality , if you need help then i can provide a simple one line piece of code depending which type of air quality device you use.
Thank you Brian, that average was indeed something I also noticed. but now fixed, after the reboot. I was not aware of an update on the meteobridge site.
Certainly, I would like that menu item AirQuality. I have a Davis Airlink. In the settings I turned off the other brands. otherwise I see nothing to expand that menu. Then apparently I need that line of code. Thanks in advance and have a nice evening and a sunny sunday Bart
Good AfternoonBart wrote: Sat May 08, 2021 6:05 pm Thank you Brian, that average was indeed something I also noticed. but now fixed, after the reboot. I was not aware of an update on the meteobridge site.
have simplified it to eradicate hard direct coding methods as this generally means being overwritten when updates are applied and everyone is on the same boat ,so simple menu option for Davis Airlink appears if
Davis Airlink option is set to Yes
Download Update 9th May 2021
* Adds Davis default menu link Ref Bart (15:20)
from menu this screen appears
Awesome! So convenient and simple. Thank you very much for this update, Brian!
Thanks Bart
Thanks Bart
started months ago but finished today .
basically revamps the forecast page with color coded temperature based background and a few additions . when hovering over forecast icons the summary forecast for the period will appear as shown below . ** with some of the icons being reworked a browser cache is likely required to cleared to reflect the changes in the SVG images.
Download Update 11th May 2021
* Reworks and overhauls forecast page (10:41)
* Adds summary forecast when hovering icons in forecast (10:41)
* Reworks forecast summary text popup (10:41)
* Reworks forecast icons *requires browser cache to be cleared (10:41)
tablet portrait mode still requires a bit more work but next weeks task..
- prestwickwx
I hope all is well. Great update to the Forecast designs.
I am seeing one problem with the daytempforecast34f.php. See below. I cleared cache, but it doesn't look that that would be the problem.
UPDATE: I think I found the problem - <?php include('../../settings.php');
You did a great job, Brian. It looks better than beautiful. It would be nice if the weather would also improve (here in the Netherlands). Is that also possible or is that outside your scope.
Thanks. Bart
Thanks. Bart
- jmontamat
Hi brian.
Also a small detail the style of the letter.
Thank you.
Thank you.
- Sin título.png (9.38 KiB) Viewed 4571 times
Ha thanks another oversight by me as my local server seems to read any path , just pushed update to Github should be fine now , also corrects or matches colors for temp related charts .prestwickwx wrote: Tue May 11, 2021 2:14 pm Hi Brian,
I hope all is well. Great update to the Forecast designs.![]()
Yes all is good here , we are now incredibly having gone from 60k new cases per day to 15k per day as of last night , 2 weeks into a 24/7 lockdown country wide has really had an amazing effect ,our area/district/street in Istanbul went from very high risk zone to low risk zone !! ..hopefully next week the curfews will be lifted to something less strict with some outdoor life.
* Forecast match colors for temp (17:56)
* Correct path to settings in non metric Ref Chuck (17:56)
* Reworks icons *requires browser cache to be cleared (10:41)
@Josep I just went to your site new font is loading fine , perhaps refresh the page a few times to force it to load.?? see below
@Bart thanks just an idea thats been lying dormant for a while glad you like it ..
- prestwickwx
Yes, I thought maybe your local server may have been the issue.
Glad to hear that things are improving in Istanbul and are gradually returning to normal.
Best wishes,
Best wishes,
- jmontamat
Thanks Brian.
Chrome stuff
Chrome stuff
