found it. my php.ini settings where not all enabled on the server
hello everybody, maybe someone nows why I only get a black window after selecting Moonphase/sunposition info in the menu ?
see also the attachment
It looked like all weather34 php's who start with something like:
include('livedata.php');header('Content-type: text/html; charset=utf-8');
date_default_timezone_set($TZ);
$TZconf = $TZ;
$result = date_sun_info(time(), $lat, $lon);time();
seems not to work.
has it something to do with my lat/lon settings? or php version?
(Weather34 Template
Version Aurora MKII
Version Date 16th May 2021
Current PHP Version 7.4.9
Weather34 Current API file size 899
CSS Theme file size dark.css 97.4KB
Timezone Europe Amsterdam
Info Loaded in 0.64421 seconds. )
please help, i cannot figure it out !!!
greetings andré
-= Weather34 MKII Vantage Moonphase/sunposition info -solved-
andredebruijn
- Fresh Boarder
Last edited by andredebruijn on Mon May 24, 2021 12:18 pm, edited 3 times in total.
Re: -= Weather34 MKII Vantage sadly No Moonphase/sunposition info =-
good afternoon
if you pm your url and setup password, you change password at anytime . i will take a look could be a simple setup oversight.with this not being being a widespread issue probably something very simple.
brian
brian
Good evening
I had access only once all your settings looked fine , unfortunately for the last 15 minutes all I got was timed out error .you may need to look at server level or some of the modifications you have applied they may be causing a conflict .that said I cant offer not much help at the moment as before as it is not widespread amongst end users can only think something locally on your side.
screenshots of timeout and errors with your url.
