Hi
In my weather network settings, Borgervejr DK is always selected, even if I try to unmark that specific network... This produces a lot of error mails (undelivered mails)... Could this be a bug?
Thanks!
Can't disable weather networks. **solved**
Re: Can't disable weather networks
I also have the same problem. The betting network "Borgervejr DK" can not be deactivated. When the mutation is saved, the actual mutation is not taken into account and the network "Borgervejr DK" remains active. Also there are undeliverable mails after each "send" of data.
regards Bernhard
regards Bernhard
- 2021-09-20 12_07_59-Window.jpg (49.1 KiB) Viewed 9054 times
As Borgervejr does no longer accept mails sent by Meteoplug on behalf of users, we disabled support for Borgervejr completely.
So just ignore the mark, it is no longer sent.
