That fixed it. Yes, there is something in 8.02 that changed with 8.07. I suspect IDC will be moving to 8.07 soon.
Have a great break :D
alexeysailman
Post by alexeysailman »
Hi, Brian!
Here I found such a thing: when you click on the "extra info" button in the barometric pressure, lines were superimposed in the name of the pop-up window. I understand that it should be by analogy, for example, with the temperature-charts for the current period, month, year?
jmontamat
Post by jmontamat »
HI Brian when you can without rushing, a small error in barometer almanac the max value month corresponds to year max.
<? php // year max
echo "" .date ('F')
for
<? php // year max
echo "" .date ('Y')
Sin título.png (28.83 KiB) Viewed 4022 times
I am seeing another strange issue, since the recent updates. Looks like my month and year charts stopped updating on June 23. Everything was fine up to that point.
hello chuck
i can verify 100% nothing has changed in many months perhaps a year or more the way chart data csv files are generated that is something completely different to the way charts are displayed recently,also nothing in relation to theme change method. so look locally check the file permissions of 2021.csv and June.csv then run a manual test through meteobridge itself. crossed check a few sites just now all are generating monthly,yearly data ok i.e all showing 25th June data at present. 23rd was the date you reinstalled master ? so probably file permission may have changed thats all I can think of if the https://yourdomain/yourfolder/weather34 ... of-day.php is present.
weatherist34 wrote: Sat Jun 26, 2021 3:26 pm hello chuck
Yep. I think some of the permissions were changed during my updates. Ran a manual - OK. I will see what happens overnight. :D
Thanks again,
jmontamat
Post by jmontamat »
Hi Bran, as a detail, couldn't the closing button be moved within the popup box like the old one?
Sin título.png (82.44 KiB) Viewed 3943 times
Bart
Post by Bart »
Because I had problems with “end-of-day” timing on my site, I opened a second (test) site around 19/6 with Weather 34 but now 'fed' by an MB RPI.
This morning I suddenly noticed a strange discrepancy between the two sites.
1) Old (MB NanoSD) preexisting site last update this morning June 27. Penultimate update that of June 19
The AQ measurements are missing on https://bdepoel.com/console/
Both in the main window and in the month map. The month card for AQ ends on 19/6.
I notice this on my iMac and on my iPhone.
2) New MB RPI extra, test, site. Newly installed with no updates, the first day in the charts is 19/6.Btw I updated an hour ago, trying to resolve the Purple Air thingy (below).
The AQ measurements are available. https://weather.bdepoel.nl/console/
Both in the main window and in the month map. The monthly card starts at 19/6 and is just filled up to and including 26/6.
That's on my iMac.
But…. On my iPhone, the name in the main window is Purple Air…also in extra info.
On both sites I have indicated that I do not have an AQ meter other than Davis. On iMac and iPhone deleted the history of safari.
What am I doing wrong or am I misunderstanding? Or did I miss the solution.
Bart
jasonmfarrow
Post by jasonmfarrow »
Re: Aurora Mk2 & Safari on MacOS - Slide-out menu doesn't work.
Anyone else seen this?
Jason
jasonmfarrow wrote: Sun Jun 27, 2021 3:12 pm Re: Aurora Mk2 & Safari on MacOS - Slide-out menu doesn't work.
Hi Jason,
I just tested Safari on Mac and I am seeing this, as well.
jmontamat wrote: Sun Jun 27, 2021 9:32 am Hi Bran, as a detail, couldn't the closing button be moved within the popup box like the old one?
no problem Josep all done but note Firefox,Safari,Chrome are beginning to render some code differently so beware there may be some minor position difference in these browsers which I can't do anything about.Sometimes I feel we are approaching another period of Internet Explorer differences .Im definitely seeing differences acrosss browsers more and more these days sometimes your lucky just a minor code change but also sometimes a rewrite of sections can occur to find a good balance.
Download Update 27th June 2021
* (16:43) Reposition Close button Ref Josep
* (16:43) Adds preperation code for themeing of chart switching based on realtime theme selection
* (16:43) Fix dark text seen seen in moonphase phrase
* I am not available till 10th July to answer emails in a timely manner.
* Update contains all updates since March 1st
Safari problems just run the update I believe it may be due to trying to force the use of latest updated jquery file which contains newer pop up layout code looks like Safari don't like it , I had seen this in this week with my own I nailed it down to js/jquery.js?ver="5" in the updater files . removing that I haven't seen it since. .
As above the update will probably resolve that and please please be patient on the newer charts there will be some temporary visual changes but these are preparation for the newer charts.The newer charts will take time to compile but once done its beneficial going forth .
we are currently on our last 24 hour countrywide lockdown day today so I took this time apply some things but thank god lockdowns has come to end for a while but inevitably they will return in the winter because I don't believe this is over yet by a long way .
jmontamat
Post by jmontamat »
Perfect Brian :)
Thank you !!!.
Bart
Post by Bart »
Does anyone has an idea about the “discrepancy” I described in my post?
Thanks, Bart
hello Bart first run the update just uploaded then pm me the setup passwords see if I can help
bart do you have this setup correctly in meteobridge nanosd itself because there is no data from airlink davis its reading zero . likelihood its been like that since 19th because the end of day values are all zero also . running multiple meteobridge devices into or from one airlink ? because the other url you provided earlier i think you mentioned is running with a RPI is displaying airlink data..
on your second url i used the same password that was set to display three air quality small modules in the bottom three sections , ive changed that to show davis airlink,forecast,sun
