Update file later today my time evening has one new optional small Cloudbase module and one reworked Fire Risk module. require to be selected in setup screen if required , being optional you can switch out according to season.
- CB-FR.png (132.93 KiB) Viewed 4016 times
- jmontamat
Hi Brian thanks for the update.
From small modules, it seems to me that the units meters, feet does not match the units C F are backwards in cludbase module.
not sure I follow do you mean you prefer meters with metric C ? I can simply make it fixed to meter, its just a relative tool I wouldn't put much accuracy into it .jmontamat wrote: Fri Jul 23, 2021 3:39 pm Hi Brian thanks for the update.
Brian
- jmontamat
I mean only the weather34-cloudbasetemp.php module.
so sorry Josep im not understanding your issue raised . im sure you can modify it to suit your requirement..
- rzelle-K1TTC
Hi Brian.
I'm seeing what Josep is seeing. I have F selected but Cloudbase is displaying C when I switch to C Cloudbase dispslay F
.. Ron
.. Ron
Got me on this one .
Ron when I goto your site it shows F(48f currently) as expected and C(9c currently) as expected .screenshot below of F and C selected
Shows 48F
Shows 9c
Shows 48F
Shows 9c
- rzelle-K1TTC
Sorry I am referring to the Base lower scale is display Meters when Temp is F
ok now i get it, you want too see it measured in ft when using F , im sure someones gonna say i want in meters
ill push an update a bit later ..many thanks brian..
- rzelle-K1TTC
Of Course ... lol
Later off to my Volunteer work ..
73s
..Ron
73s
..Ron
- jmontamat
If I already adapt it, the issue of height units feet / meters is confusing for me.weatherist34 wrote: Fri Jul 23, 2021 4:53 pm so sorry Josep im not understanding your issue raised . im sure you can modify it to suit your requirement..
Josep /Ron I have set it to use what ever option you set in the setup screen meaning it is a fixed setting for height ft or mt .now back to my Polk Salad
- jmontamat
I like it so
- rzelle-K1TTC
That Works
..Ron
..Ron
