jmontamat
Post by jmontamat »
Hi Brian in weather34-cloudbasetemp.php units meters the bar does not progress according to the value.
Good weekend.
Sin título.png (12.41 KiB) Viewed 4084 times
try the update just pushed to GITHUB might be better I threw loads of scenarios at it , it seemed ok but who knows can't test all scenarios but I tried from 100 meters to 10,000 meters
jmontamat
Post by jmontamat »
Thanks Brian now it's fine.
hope to roll this out tonight , its a simple straight forward no thrills alternative display to use on smart tv or tablet , big bold numbers no requirement of graphics just a simple big number display . access via menu .will post a photo later of it on Smart TV .. as mentioned no thrills , low resource , purely optional ideal for those wanting something clear to look at from a distance or afar ,good for my eyes upto 25 feet or more .
bottom modules work on what if scenarios from sensor values ,heat index, windchill,firerisk etc and options set in setup based on hardware i.e air quality,lightning etc
This looks like a nice addition for my old eyes. :D
prestwickwx wrote: Wed Jul 28, 2021 3:46 pm Hi Brian,
me too deteriorating yearly been struggling of late beyond sitting in front of it (ipad pro) i cant focus ☹️.. should see rev 1 😁 im sure there will be a few , its on github now just be a bit patient ill gradually add some more options for bottom row dont want to go too far with it ,its just a straight forward alternative doesnt break up main layout and all original charts,etc are fully accessible via main dashboard layout.
OK. I just uploaded. Will check it out.
Hope that's to the liking of others , its a very simple dashboard layout that is optionally viewed via the menu .
no thrills just your data and simple css :-) , clicking on chart icon shows the familiar history info data,charts.
supports optional alerts based on your data
supports purple air,davis airline,luftdaten,weatherflow lightning small modules .
supports solar view if you have no uv sensor , if you have neither uv, solar , at present there is no option at the moment so be patient whilst I drum up a solution that works .
Download Update 29th July 2021
* (11:08) Adds new simple dashboard view option via menu
that's it ..
jasonmfarrow
Post by jasonmfarrow »
Brian, I like it. I replaced the Solar with AQI (UK values) on mine...
Jason
I get different wind forecast values in chartforecast.php and weather34-dayforecast.php modul:
In weather34-dayforecast the reason for the different display is the conversion
code ($wuskydayWindGust*1.625,0)
This seems to be wrong?
rzelle-K1TTC
Post by rzelle-K1TTC »
The alternative display looks good on the older ipad 6th gen I've dedicated to the Template.
BTW I had both eyes fixed back in Jan. and Corrected to distance so readers are must now ... lol but can now drive again without.
Nice Job! I'm keeping the new version up on the older ipad now
..73s
..Ron
@Jason looks cool glad it works for you
@Torsten to achieve a predicted wind gust throw a multiplier of 1.625 at it , it will be relatively close ,* note the word relative :-) if 28kmh wind speed is forecasted here then generally the wind gusts are in the upper 40-50kmh range, living in a rather generally all year round gusty location this works relatively well .that said if you don't agree feel free to remove the multiplier .
@Ron be patient with me im still ironing out minor things to make sure it doesn't get over busy and keep it relatively easy on the eye and just use it for what it is.
looks sweet on a iPhone 12 :-)
I will have to add another module for those without a UV sensor or Solar only thing I can think of universally is a Clock :-) not getting sucked into another multiple choice :-)
* (16:34) Set compass to use current and day average in simple dashboard
* (15:44) Cleans up unused Dev code in simple dashboard
* (15:44) Adds CSS alignment for wind in simple dashboard
* (15:44) Adds refresh Icon to simple dashboard
Just grabbed the latest - I assume you removed the Charts, don't see them on mine.
Looks nice and clean on my tablets. :D
hi chuck it got too busy didnt work for me based on keeping it relatively clean , i just put this together as I needed something big and bold to hang on the wall on the balcony :D.. perhaps i could just add the chart icon link too bottom toolbar ? also i could add if no lightning today show feels/heatindex/windchill small module ?
I don't really have a preference. I like the large bold letters for my tablet or distance viewing. It's easy enough to get to the detailed info if needed. So, I like it either way.
"also i could add if no lightning today show feels/heatindex/windchill small module ?" - this would be good :D
