ngiovas wrote: Tue Aug 03, 2021 6:26 pm
weatherist34 wrote: Tue Aug 03, 2021 6:06 pm
good evening
you need to look at server level folder/file permissions, also looking at your today charts there is no data so start with folder/file permissions in all folders ..
as for importing history chart data fix the folder /file permissions if it is the root cause first and ill help with importing data .
brian
Thank you, that was the issue. I had checked the permissions before posting, but it appears that on one of the folders, the changes were not applied to the files within the folder. The charts and forecasts are now working properly.
I see the directories for the historical data. Am I able to directly copy the data from the old directories in so that I can display the historical data, or does the new template use a new format?
Nick
Good morning nothing todo apart from a couple of lines out of sync in 2020.csv , they are limited in comparison to new version output but just drop the 2019.csv/2020.csv into the current weather34charts .
,you will have some anomaly due to no uv or solar present in your chart data in these files . also I would grab the latest update download and go through the settings in the setup to insure all modules relate to your hardware .
Download Update 4th August 2021
* (08:18) **This Update is all related to alternative display
* (08:18) *****This Is Very Important set 3 new options in setup screen *****
* (08:18) *****If you dont alternative view will not work properly !!!!! *****
* (08:18) Adds color code legend to wind direction
* (08:18) Correct degree symbol in cloudbase module
* (08:18) Adds indoor temperature trend arrow
- dir.png (78.4 KiB) Viewed 6115 times
