perhaps its not clear you can use outside(I use mine outside) or inside just assign the mapping accordlingly so outside is your primary but template does not support/display both(2 airlinks) simultaneously .confused ? so am I when it comes to supporting multiple brands/mapping of sensors.. :D
Download Update 15th August 2021
* (16:58) **Adds a basic module to support Ecowitt lightning
* (16:58) **Adds 2 options in setup to use Ecowitt basic lightning module
* (16:58) **Ecowitt lightning must be mapped to [lgt0----] example [lgt0total-daysum.0:--]
* (16:58) **Adds Humidity forecast if no UV,SNOW,RAIN,HEAT INDEX
Ecowitt lightning is a very basic module in time I will look into chart data but not at the moment something is better than nothing.
you will need to create a separate service to run which I will publish in due course , it simply is just a few strings as we don't need a full blown API this will also enable chart data to be logged daily, monthly,yearly as seen here in a live example with weatherflow lightning module https://myrtleweather.com/console/index.php
jasonmfarrow
Post by jasonmfarrow »
wrong quote - deleted.
Jason
jasonmfarrow
dtrop1 wrote: Sun Aug 15, 2021 12:23 am Thanks for the reply.
Bummer, but I pay attention more to outside air quality.
The mapping is done at the meteobridge level. Brian's template accepts only one set of Davis Airlink PM1/2.5/10 values along with the temperatures which can be Indoor or Outdoor. If you have two Davis Airlink sensors then it will be your job to use the Meteobridhe mapping options to choose one of these (the indoor or the outdoor, or whatever arrangement you have) to be pushed via the Weather34 API.
Also, as you'll have seen from other posts in this extensive thread, the Weather34 API has only a limited number of slots for data and there's not enough spare API slots to accomodate a second set of PM data. Nor, I would guess, is there a large user-base of persons owning two identical sensors.
However, if you can do the coding, perhaps using Brians template code as examples, you can create your own pages to present any additional data. You'll have to setup your own "service", from meteobridge or other tools, to push the second set of PM & Temp data to your own website and then manually code some pages on your website to use the secondary data.
I have A Davis Airlink, fully supported by Brian's template, and a Nova SDS011 AQI sensor (driven by a Raspberry PI), to gather a second set of data to compare the two sets of readings: Very different data but it can be done. Just not necessarily in the Weather34 default Template. Many others customise upon Brian's template as their skills permit. Other just enjoy the presentation as-is.
Jason
Ecowitt Lightning
c. Ecowitt Lightning Only
To use the basic Lightning module when using a Ecowitt or alike sensor you need to run this in the meteobridge service Select the Services Tab
1. Goto Select new service
2. Select from the drop down menu HTTP Request
3. Select periodically in the next menu
4. Click Save at the bottom of the screen
5. Now look for new HTTP request
6. select 1 minute
7. NOW INSERT THE URL with the appending script and required strings examples and note please inspect the string
8. https://yourdomain.com/aurora/mbridge/m ... ing.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0total-nonzerotime:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
8a. https://yourdomain.com/console/mbridge/ ... ing.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0total-nonzerotime:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
9. now click save .
10. * Make sure you have entered the appending string correctly in the meteobridge services setup up screen
11. * In the template setup screen you can select the module weather34-lightning-eco.php or if using Alt/OS theme select
weather34-lightning-eco-tablet.php
*The structure for the basic simple string
mb-lightning.php?d=[lgt0energy-act:--] [lgt0dist-act:--] [lgt0total-nonzerotime:--] [lgt0total-daysum.0:--] [lgt0total-monthsum.0:--] [lgt0total-yearsum.0:--] [lgt0total-sum10.0:--]
setup info page https://weather34.com/homeweatherstatio ... guide.html
live example using basic lightning module http://ringwoodweather.ddns.net/Aurora2/index.php
PS ..as far im going with this brand for now so please no requests for other sensors from the brand.
Brian
jmontamat
Post by jmontamat »
Ahora funciona !! en pataformas Dir-505, tp-link y RPI.
Gracias Brian Boris por su esfuerzo y dedicacion.
Josep rica ederim arkadaşım :-)
Download Update 16th August 2021
* (10:48) **Update for Alt/OS Theme layout
* (10:48) **Adds cloudbase temp to feels module if no heat index,windchill
hopefully last update for a while once again all related to Alt/OS theme .thank you for the ideas/feedback but lets keep it simple and stick to the original principal of a simple layout.
Download Update 17th August 2021
* (07:28) **Update for Alt/OS theme update
* (07:28) **Adds month rain total if no rain rate
* (07:28) **Adds true last strike timeago for Ecowitt lightning modules
* (07:28) **Adds wind average trend arrow
for Ecowitt Lightning Sensor use see end of setup guide
here Setup Info Guide https://weather34.com/homeweatherstatio ... guide.html
alexeysailman
Post by alexeysailman »
Hi, Brian!
I'm back "as always" with my mmHg) If it's not difficult for you, could you make this pressure dimension on weather34-tablet.php when enabling mmHg in the settings?
Thanks!
alexeysailman wrote: Tue Aug 17, 2021 8:45 am Hi, Brian!
Thanks!
Hello
try the update just added basically interacts with position 8 using mmHG in main dashboard view .
* (10:17) **Adds Pressure module mmHG for Alt/OS Theme
alexeysailman
Thank you for your speed!
Only here there are no readings and when you hover over the pressure module, the cursor appears in the form of a cross. As I understand it, it should be similar to other modules - when you click, a pop-up window with a history appears
Hi you have a 404 returned on the file barometermodmmHG-tablet.php so you need to check if was uploaded to your server
https://морская10метео.рф/barometermodmmHG-tablet.php
Screenshot at Aug 17 10-35-28.png (65.84 KiB) Viewed 5776 times
alexeysailman
Strange... File barometermodmmHg-tablet.php on the server there is and if I have this link in the address bar of the browser, insert it: https://xn--10-6kcwaznenhomt1p.xn--p1ai ... tablet.php, then it will look like in the second attached picture
https://морская10метео.рф/barometermodmmHG-tablet.php returns a 404
so do you have a redirect or rewrite of url ?
see console log error the url is different
very sorry can't help, you will have to resolve at server level ,console log reveals the anomalies
continuous string of 404 returns
Screenshot at Aug 17 11-31-08.png (190.09 KiB) Viewed 5762 times
solution download the update again and run it that should resolve it . your server is case sensitive configured? so I've adjusted the updater-tablet.php file to comply with that.
* (11:45) **Fixes case sensitive server configurated for mmHg Ref Alex
have a good day ..Brian
