alexeysailman
Post by alexeysailman »
Hurray! Thank you so much, Brian. Everything works as it should!
Was hoping I was not going to have any updates todo but wake up to something as usual :( , ref Ecowitt lightning im not getting sucked into this brand , there is an issue with using nonzerotime for last strike in Meteobridge , the nonzerotime [lgt0total-nonzerotime:--] string does NOT produce a valid timestamp of any sort after a day or more , exactly how long I don't know ,so provide I provide this info and hopefully users can liase with Boris with their findings .Im not the person who can resolve this as Ive seen this for a few years with rain when using nonzerotime ."resolving nonzeotime is a tedious task because the outcome is not immediate you may have to wait a day or more to see if it is resolved ".. food for thought does it only reproduce an anomaly after a meteobridge reboot/firmware upgrade ? and requires a strike to resolve ..have a good day
screenshots below .
Download Update 18th August 2021
* (09:03) ** Adds fallback for lightning if nonzerotime value is not present
* (07:50) ** Update for Alt/OS theme update
* (07:50) ** Adds forecast module option
* (07:50) ** Aligns indoor module
* (07:50) ** Minor css alignment for phrase last strike
* (07:50) ** Rework of the feels like module
* (07:50) ** Ecowitt last strike does not function this is a meteobridge or hardware brand problem has the nonzerotime does not produce a timestamp it seems after 1 day or more. fallback for no timestamp data has been added.
for Ecowitt Lightning Sensor use see end of setup guide
here Setup Info Guide
newer features in update
jmontamat
Post by jmontamat »
Good morning Brian, if the forecast description is too long, it collides with tomorrow.
Sin título.png (18.11 KiB) Viewed 5971 times
thanks see GITHUB file ...but I really think every new idea/suggestion just brings more problems , many go unseen or impossible to plan for when compiling ideas . weather template development truly sucks at times its a chore todo the most simplest of ideas !!! there is no happy medium it just gets tedious . so please I kindly ask @all no more ideas, just take the template for what it is and if doesn't meet your requirements there are plenty of others to use ..
Screenshot at Aug 18 11-59-06.png (43.67 KiB) Viewed 5968 times
jmontamat
Post by jmontamat »
The idea of ​​forecast in ALT mode is good, I'll adapt "str_replace (" to my needs.
try the file just pushed to GITHUB might be easier to manage for you :D
jmontamat
Post by jmontamat »
In Spanish they say "A grandes males grandes remedios " :D
Thanks !!!
Download Update 19th August 2021
* (07:31) ** Update for Alt/OS theme update
* (07:31) ** Replaces forecast phrase with Icon Ref Josep
* (07:31) ** Reworks clock sunrise/set layout
* (07:31) ** Adds fallback for GW1000(alike) lightning sensor with blank nonzerotime
forecast icons replaces phrases
with valid lightning distance
fallback for blank nonzerotime in lightning (N/A)
with valid nonzerotime in lightning
Download Update 20th August 2021
* (10:11) ** Update for Alt/OS theme update
* (10:11) ** Adds option to show indoor module or not in mobile view Ref Daniel
* (10:11) ** Adds forecast module to mobile view
for those with no use for indoor temperature or concerns and for those wanting forecast in mobile view .
have a great weekend..Brian
As always once the newer idea becomes stable its good to remove all the accumulated Dev code which always happens , with that comes a nice load performance result and a happy server .screenshot below of load time with ICDSOFT hosted server a result of less than 1 second == 0.8 seconds !! !!! results also depend how your server is configured .
Download Update 22nd August 2021
* (10:11) ** Fixes KTS format in average wind module
* (10:11) ** Removes all Dev code reduces load time
*Please note as of September 1st update file will only contains files updated from September 1st not March 1st..
Screenshot at Aug 22 09-31-52.png (197.62 KiB) Viewed 5818 times
Hope all is well. The performance here looks great, too.
One minor bug I noticed yesterday, during a rain storm. The pop up notification was reporting the rain rate with a suffix of mm/hour while the rain module was reporting (correctly) with a suffix of in/hour. The numerical value was correct - just wrong units.
Best wishes,
Ha thanks that's what I get for having no rain for 2 months or more ! see GITHUB for fix ..amongst other minor changes.
Got it! :D
Cool so you should end up with something like this screenshot as of last GITHUB push and download was updated to ensure it all renders in Firefox accordingly .
* (17:14) ** Update for Alt/OS theme
* (17:14) ** Missing non metric rain unit notification Ref Chuck
* (17:14) ** Adds Firefox compatibility for alignments in all modules
* (17:14) ** Adds temp day max|min to temp,dewpoint,humidity
When I change the units in the almanac, I can no longer switch back to the main view via Home.
