Update now has all necessary files for upgrading to use forthcoming paid version. please note you are not forced to use paid version this version will continue to work , there is no nag screens to prompt you or bug you . when forthcoming release is done simply to use or access updates you will require an account . Hopefully soon the backend CMS(control management system) for accessing downloads etc will be complete .
Download Update 24th August 2021
* (09:14) ** Update for Alt/OS theme *Significant
* (09:14) ** Reworks how metrics are displayed and handled
* (09:14) ** Better handling for mobile view use
* (09:14) ** Remove almanac data screen and moved data to info screens
* This update contains files to be able to upgrade for future paid release(target release date September)
in this update it utilizes the menu to ensure your chosen metric options are viewable . see screenshot .also removed almanac screen and as chuck put it smartly consolidated it into existing info screens as basically it's the same identical data .
Sometime in September the API will have more data and some removed like Davis console forecast,Lightning which consumes quite a lot of data in the API output so things like year averages, month averages etc will appear.you will still be able to use lightning via a separate small custom API which has been described in the setup guide page .
If you are not a Davis hardware owner then I advise you not to even bother with forthcoming paid version and waste your money I simply will not be held accountable and any inept complaints you should read what Im saying here before firing off ,
it will be primarily for Davis hardware owners . The forthcoming paid version is not about making money, paying for my time etc its purely about raising funds to be able to purchase a necessary license for distribution of new chart library .
- 1.png (228.96 KiB) Viewed 6559 times
Brian
