Have a nice day.
- jmontamat
Sorry, my problem when making the update, I'll have another coffee.
Have a nice day.
Have a nice day.
- prestwickwx
Your custom code was perfect!
No problem, I have a few files that I customize each time. I like keeping the tool bar with minimum choices. Now, with the different screen options, I find that those are the most used on my Large touch screen monitor. I set it so the 2 alternate choices are available from whatever screen you are presently viewing. The units are available in the Menu and that seems to be fine. I also try and keep all 3 menus the same.
Everyone has different uses and you have provided a multitude of options.
Take care,
Take care,
good stuff as long as your happy and it works for you thats all that matters ...prestwickwx wrote: Sat Oct 09, 2021 4:36 pm Hi Brian,
Your custom code was perfect!No problem, I have a few files that I customize each time. I like keeping the tool bar with minimum choices. Now, with the different screen options, I find that those are the most used on my Large touch screen monitor. I set it so the 2 alternate choices are available from whatever screen you are presently viewing. The units are available in the Menu and that seems to be fine. I also try and keep all 3 menus the same.
Everyone has different uses and you have provided a multitude of options.![]()
Take care,
a couple days ago Boris released a firmware update that deals with the nonzerotime in rain anomaly after 3 days . I have three files to push to GITHUB that have been adjusted to accommodate the fix from Boris . So if your ok updating the Meteobridge firmware on your NANOSD then ill push them to GITHUB .the three files are nothing todo with your modifications or menu all rain related modules basically shows last rain in minutes, hours,day,days,months if no current rain rate present .
released October 6/7, 2021:
Meteobridge PRO, NANO SD, RPI: fixes another bug that prevented from having "nonzerotime" evaluated correctly for more than 3 days in the past.
Hi Brian
I think all the latest updates are great - thanks for all your work
I have a suggestion that I would like to see - hopefully its nothing major and please feel free to ignore it
I would quite like to see when my Davis AQ monitor and Purple Air monitor got their last data update so maybe in the extra info have a Last Updated field
I dont know if its possible to get this but sometimes my AQ monitors go offline for some reason and it would be quite handy to check when the last data update was done
Graham
Graham
- prestwickwx
Brian,weatherist34 wrote: Sat Oct 09, 2021 5:08 pmgood stuff as long as your happy and it works for you thats all that matters ...prestwickwx wrote: Sat Oct 09, 2021 4:36 pm Hi Brian,
Take care,
No problem. I just updated to the latest Meteo firmware.
just pushed to GITHUB ..check back tomorrow sometime got a 4am alarm to get up to watch the boxing ...hope it works if not can easily revert back to previous files..
- prestwickwx
No problem. Just uploaded the files.
looks like it’s working as expected see ron site its showing 4 days ago ive never seen a value after 3 days prior to this change.
https://weather.k1ttc.com/AuroraMKII/we ... tablet.php
- jmontamat
As Information it looks perfect on Samsung galaxy A71 android 11.
Thanks Brian.
Thanks Brian.
- Screenshot_20211010-143253_Chrome.jpg (101.86 KiB) Viewed 6211 times
- Screenshot_20211010-143903_Chrome.jpg (104.75 KiB) Viewed 6211 times
thank you Josep good to know , don't own anything android etc ..
ps Im finally buying a boat tomorrow so responses and updates for the foreseeable future will be sporadic..
Download Update 11th October 2021
* (14:45) * Update all additions from March 2021 to October 11th 2021
* (14:45) *** This update requires latest meteobridge firmware later that 5th October
https://wiki.meteobridge.com/wiki/index.php/Forum
* (14:45) * Adds reworked code for time since last rain
* (14:45) * Adds extended since last rain (nonzerotime) caters for months,days,hours,minutes since last rain
* (14:45) **New** Adds mmHG option in setup screem
* (14:45) * Adds Max solar to solar modules if no UV sensor
* (14:45) * Removes some unused CSS
* (14:45) * Minor tooltip color/alignment adjustment/
examples below of since last rain
I'm starting to see weird things. Is that bad? I have installed the update from October 8. I see that there is an update, October 11. Arrived on the download site (new so take a good look) it says there is an update of 1 day old. That's the 13th. I download that. But just when I want to upload it I see that it is dated the 8th. But that's exactly what I already have.....sniff
Am I really confused?
Bart
Bart
- jmontamat
Good Morning Brian.
If it is foggy, it goes out of the box.
- Sin título.png (11.91 KiB) Viewed 6036 times
- jmontamat
Thanks, updated
- Sin título.png (10.29 KiB) Viewed 6023 times
Hello Bart sorry been updating design of website and adding some automated features to make it a bit easier to update with relevant information. Basically I was using an old timed upload so I could compile the time ago updated script to work remotely from the uploaded files.Bart wrote: Thu Oct 14, 2021 2:06 pm I'm starting to see weird things. Is that bad? I have installed the update from October 8. I see that there is an update, October 11. Arrived on the download site (new so take a good look) it says there is an update of 1 day old. That's the 13th. I download that. But just when I want to upload it I see that it is dated the 8th. But that's exactly what I already have.....sniff
Am I really confused?![]()
Bart
hope its ok now ?
Josep sorry should have had a else if for mist !
new download page layout and keeping with evolving traditions it has now a light/dark option .
have a good weekend .. now what was that famous song by Rod Stewart ?
