Ok perfect thank you
but I don't mind the mbbridge files are in a folder, if I just enter the path to the file on the setup it gives me an incompatible weather station error ..
Good morning only thing I can think is are you using a altervista based web host service , in the past these have been troublesome when dealing with paths. thing todo send your setup screen password and url to website via PM failing that I can put you in touch with a native Italian speaker if required to help resolve, you can change the password at anytime .ill take a look to see if I can fathom it out for you..maltempo wrote: Fri Oct 22, 2021 8:10 pm Ok perfect thank youbut I don't mind the mbbridge files are in a folder, if I just enter the path to the file on the setup it gives me an incompatible weather station error ..
in the update there are new options to set in the setup screen to choose what layouts you would like to use .so please set those options according to your preference .screenshot below .
Change Log 23rd October 2021
* (09:56) * Contains all features/fixes from Oct 1st to Oct 23rd
* (09:56) * Requires Meteobridge firmware (6th Oct or later)
* (09:56) * Requires to ** setup new setup screen options
* (09:56) * Adds new theme layout options to setup screen
* (09:56) * Cleans up forecast page code
* (09:56) * Removes unused SVG images from AQI folder
* (09:56) * Adjust humidity color code in charts
* (09:56) ** mmHG *** modules require the setup screen option !!
* (09:56) * NAG screen is removed supports standard configuration !!
ok should be fine now you had a hidden white space on end of the path , don't worry it happens . the path is and set as recommended mbridge/MBrealtimeupload.txtmaltempo wrote: Fri Oct 22, 2021 8:10 pm Ok perfect thank youbut I don't mind the mbbridge files are in a folder, if I just enter the path to the file on the setup it gives me an incompatible weather station error ..
if you cut and paste its always worth checking or deleting any hidden white spaces on the end .
ps you can update the template by using the simple updater but beware altervista hosted sites have problematic outcomes that I can't always resolve..
ps do NOT edit the settings file direct , you had many strange options set with Italian phrases , these are not recognized and that will cause template too malfunction . there is 100% no need or requirement to edit settings files directly that is the whole purpose of having a setup screen and using the setup screen eradicates the old school method of editing files directly and reduces the error rate considerably.
so beware its an English only supported template ..
have a good weekend ..Brian
alexeysailman
- Expert Boarder
Hi, Brian!
Here I noticed a couple of "oddities": in the attached screenshot, the humidity history for the month and year disappeared; if you select the rain history for 2021 with an increase (use zoom), as in the second attached pic, you can see that it repeats twice.
Well, as a "sore point" for me personally: for the page https://xn--10-6kcwaznenhomt1p.xn--p1ai ... tablet.php when the "Use fixed mmHg Barometer module" option is enabled in the settings, this is the story as in the third screenshot.
- 24-10-2021_121933_xn--10-6kcwaznenhomt1p.xn--p1ai.jpeg (144.77 KiB) Viewed 5833 times
- 1_xn--10-6kcwaznenhomt1p.xn--p1ai.jpeg (192.96 KiB) Viewed 5833 times
- xn--10-6kcwaznenhomt1p.xn--p1ai.jpeg (193.63 KiB) Viewed 5833 times
hi Alex I can not reproduce error you see for mmHG ..this has always been problematic for as long as it has been there so its time to remove the mmHG feature .im so sorry but Im at a loss because as you can see it works for me .
I have fixed the rain/humidity in charts my error oversight on position of humidity ..
Change Log 24th October 2021
* (13:33) * Contains all features/fixes from Oct 1st to Oct 24th
* (13:33) * Requires Meteobridge firmware (6th Oct or later)
* (13:33) * Requires to ** setup new setup screen options
* (13:33) * Adds new theme layout options to setup screen
* (13:33) * Fix Humidity month/year charts Ref Alex
* (13:33) * Fix duplicate rain array in year charts Ref Alex
* (13:33) * Adds wind speed indicator bar
* (13:33) * Adds rain rate indicator bar
my setup using mmHG so I don't know the answer ...
mmHG charts
mmHG charts
alexeysailman
- Expert Boarder
Thank you, Brian, for responding so quickly. It's really strange that it works like this for me,
although I've tried it on different devices (iPad, Iphone 12, PC with win 10...). So maybe
you won't completely remove mmHg after all? At least leaving everything as it is? A lot of
work has been done on the implementation of this unit of measurement. In addition, everything
works fine in the Aurora MKII (Vantage-ALT) and in the observation history.
hi alex i dont know the answer or have a solution.. it works for me using that option . so i simply have run out of ideas to find a smooth solution without hardcoding which i dont want todo in anyway because updates will simply break it. so last idea send me your setup screen password via pm you can change at anytime. thats all i can do to perhaps compare with what i have set ..brian
today would be a good time any other time this week is problematic..
I took a look at your settings I see nothing wrong , but I can see it now in the browser resource error log and I think Josep may have mentioned this about mmHG case sensitive . when I checked your site it returned a 404 for the mmHg file .so the file was there but your server is case sensitive so it needs to be exact . so please download the update again and run it I have just applied the fix. say thanks to Josep not me has I misunderstood what he was raising a week or so ago ..alexeysailman wrote: Sun Oct 24, 2021 1:06 pm Thank you, Brian, for responding so quickly. It's really strange that it works like this for me,
* (14:46) * Contains all features/fixes from Oct 1st to Oct 24th
* (14:46) * Requires Meteobridge firmware (6th Oct or later)
* (14:46) * Requires to ** setup new setup screen options
* (14:46) * Adds new theme layout options to setup screen
* (14:46) * Server mmHG case sensitive fix Ref Alex
* (14:46) * Fix Humidity month/year charts Ref Alex
* (14:46) * Fix duplicate rain array in year charts Ref Alex
* (14:46) * Adds wind speed indicator bar
* (14:46) * Adds rain rate indicator bar
hope that fixes it..Brian
alexeysailman
- Expert Boarder
Everything is fine, except that the link to the barometer data history page "broke" when you click on the "CHART DATA" button (this applies only to the page weather34-os2-tablet.php ).
I repeat once again: I hope that you, Brian, will change your decision on "...delete the mmHg function.".
alexeysailman wrote: Sun Oct 24, 2021 2:17 pm Everything is fine, except that the link to the barometer data history page "broke" when you click on the "CHART DATA" button (this applies only to the page weather34-os2-tablet.php ).
I repeat once again: I hope that you, Brian, will change your decision on "...delete the mmHg function.".![]()
Alex your server is case sensitive !! you can disable this in htaccess but I'm not going to publish how to do that as that's a recipe for those unfamiliar with htaccess to break servers/configurations. do a google search will probably return numerous ways ..
can you just re download the update AGAIN and run it ..please I hope this resolves mmHg because its hard to fathom out all these various requirements ..
alexeysailman
- Expert Boarder
Thank you so much, Brian, for your patience! Everything works fine!
lorenz1982
- Expert Boarder
Small mistake.
On the alternative and OS display there is a mistake about forecast.
The actual forecast is the same for the forecast of tomorrow.
- B437F10F-2FF5-408D-A920-4E23C7994910.jpeg (59.02 KiB) Viewed 5777 times
Hi Lorenzo
was fixed late last night so 25th update should be fine now . in short localized problem the master folder became corrupted , however thankfully due to auto hourly time machine backups I was able to restore with ease.
Change Log 25th October 2021
* (06:15) * Contains all features/fixes from Oct 1st to Oct 25th
* (06:15) * Requires Meteobridge firmware (6th Oct or later)
* (06:15) * Requires to ** setup new setup screen options
* (06:15) * Adds new theme layout options to setup screen
* (06:15) * Fix incorrect forecast Ref Lorenzo
* (06:15) * Restores master folder from backup after corrupted locally
sorry for the inconvenience ..Brian
- jmontamat
Hi Brian, it would be possible to correct this transparency.
- Sin título.png (34.05 KiB) Viewed 5679 times
- jmontamat
Solved !!!
Tnx.
Tnx.
