Loss of connection to the Davis Datalogger
MrPippoTN
Post by MrPippoTN »
Hello everyone, I would like to submit to you a problem that I have been experiencing for some time with a meteobridge that I have personally configured starting from a TP-LINK TL-MR3020v3.
This meteobridge transmits data from a Davis Vantage Pro 2 online and apparently works fine. The weather station is located in Italy, near the city of Bolzano (Bozen), in South Tyrol.
The station is registered with Weather Underground:
https://www.wunderground.com/dashboard/pws/ITRENTIN122
I also created its dedicated web page with Weather34:
http://www.meteotrentinoaltoadige.it/st ... rora-MKII/
The problem consists in the constant disconnections of the Davis Datalogger. Let me explain: the station works correctly for a few hours but, at a certain point, for some reason, the meteobridge is no longer able to interface with the Davis Datalogger and begins to publish missing data on the internet (in fact, horizontal dashes like these : "--").
The only way I have to get the meteobridge back to work is to restart it remotely. So I decided to set up a script that makes it restart every six hours, but sometimes when I go to consult the weather station data on the web I realize that the station is not uploading the data correctly anyway.
I specify that where I have installed the station I do not have a wired connection to the Internet, so the data is uploaded via the mobile network, with a sim card and a 3g / 4g modem of the Teltonika brand. Apparently, the Internet connection works perfectly: the meteobridge is always online, the problem is that it sends empty data packets to the Internet.
Now I've just restarted the meteobridge and everything seems to work fine but I'm sure it will disconnect soon.
I post the latest log:
wnetd  (25.10.2021 14:58:38): process started.
system (25.10.2021 14:58:38): start of logging process initiated.
wnetd  (25.10.2021 14:58:39): send data thread started (pid:2135 tid:2137)
logger (25.10.2021 14:58:39): historical data loaded (25 records).
logger (25.10.2021 14:58:39): data logger (version 5.2, build 14619) started.
logger (25.10.2021 14:58:40): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (25.10.2021 14:58:40): station 0 (Vantage), connect to station failed.
logger (25.10.2021 14:58:43): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (25.10.2021 14:58:43): services paused.
logger (25.10.2021 14:59:10): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (25.10.2021 15:00:10): message above repeats 2 times.
logger (25.10.2021 15:00:40): give up waiting for sensors after 120 secs.
logger (25.10.2021 15:00:40): services activated.
logger (25.10.2021 15:00:40): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (25.10.2021 15:01:10): connect station 0 (Vantage via USB serial).
logger (25.10.2021 15:01:10): station 0 (Vantage), wakeup sent.
logger (25.10.2021 15:01:22): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (25.10.2021 15:01:22): station 0 (Vantage), internal logger activated.
logger (25.10.2021 15:01:22): station 0 (Vantage), syncing.
logger (25.10.2021 15:01:22): station 0 (Vantage), gettime request sent.
logger (25.10.2021 15:01:22): station 0 (Vantage), communication with Davis console/envoy seems to be stalled. Please power cycle the console/envoy by (1) disconnect from AC, (2) remove batteries and (3) disconnect USB. Wait a minute and power on again. Weak batteries need to be replaced.
logger (25.10.2021 15:01:32): station 0 (Vantage), gettime request sent.
logger (25.10.2021 15:01:32): station 0 (Vantage), no Vantage time offset.
logger (25.10.2021 15:01:32): station 0 (Vantage), eeprom request sent.
logger (25.10.2021 15:01:32): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (25.10.2021 15:01:32): station 0 (Vantage), transmitter 8 active as station type #0 "ISS".
logger (25.10.2021 15:01:32): station 0 (Vantage), firmware version request sent.
logger (25.10.2021 15:01:48): station 0 (Vantage), no firmware version returned.
logger (25.10.2021 15:01:48): station 0 (Vantage), no reading of Vantage's internal logger.
Has anyone ever had similar experiences? Any suggestions?
Re: Loss of connection to the Davis Datalogger
Something with the USB connection to the logger is instable.
This is not a SW but a HW issue.
MrPippoTN
Post by MrPippoTN »
admin wrote: Thu Oct 28, 2021 11:00 am Something with the USB connection to the logger is instable.
Any suggestion? Please... Even buy some new hardware, like console or datalogger...
