Coolweatherist34 wrote: Sat Nov 13, 2021 12:26 pm @chuck something to amuse you with Apple Watch ..![]()
download app on App Store for iPhone called free Parity https://apps.apple.com/us/app/parrity/id1448208309
- jmontamat
Hello, a question about cloudbase:
According to the formula of:
https://www.omnicalculator.com/physics/cloud-base
cloud base = (temperature - dew point) / 4.4 * 1000 + elevation
Or - altitude for station and cloudbase values to station level
the elevation of the station is not plucked in livedata.php
$weather ["cloudbase"] = ($cloudbasetemp - $cloudbasedewpoint) /4.4*1000;
lorenz1982
- Expert Boarder
Hello.
Is it possible to have solar radiation here instead of UVINDEX?
- IMG_1696.jpg (418.24 KiB) Viewed 6638 times
@Josep @Lorenzo
sorry its a short response but both requests added .
Change Log 15th November 2021
* (10:20) * Contains all features/fixes from Oct 1st to Nov 15th
* (10:20) * Adds new setup screen option to set elevation (Ref Josep)
* (10:20) * Adds new setup screen option to set 9th position module (Ref Lorenzo)
* (10:20) * Adds warning module if position 9 not set in setup screen
lorenz1982
- Expert Boarder
Thanks.weatherist34 wrote: Mon Nov 15, 2021 9:29 am @Josep @Lorenzo
I have updated but there are these errors.
How can I do?
- Immagine 2021-11-15 084049.jpg (150.33 KiB) Viewed 6597 times
lorenz1982
- Expert Boarder
I solved.lorenz1982 wrote: Mon Nov 15, 2021 9:43 amThanks.weatherist34 wrote: Mon Nov 15, 2021 9:29 am @Josep @Lorenzo
How can I do?
I have edited "console-settings.php".
- jmontamat
Perfectly understood.
as above Lorenzo set the elevation in the setup screen no need to edit files anyway you have it working but future reference if you see *new setup option mentioned in change log’s it means there is a new option to set.lorenz1982 wrote: Mon Nov 15, 2021 9:59 amI solved.lorenz1982 wrote: Mon Nov 15, 2021 9:43 amThanks.weatherist34 wrote: Mon Nov 15, 2021 9:29 am @Josep @Lorenzo
How can I do?
have a good week…brian
- rzelle-K1TTC
I applied the last updates via Git and see the warning screen for the 9th model. When I run setup and select a module for the 9th I can't get back into the main template screen or the setup screen. I receive a 505 error for the main and a 404 when I try to go back into the setup. It's a good thing I keep backups of my console-settings.php. When I restore the console-settings I can access my main template again and the Alt but the warning for 9th is still appears of course.
Hope all is well ..
.. Ron
Hope all is well ..
.. Ron
lorenz1982
- Expert Boarder
Yes, I was wrong.weatherist34 wrote: Mon Nov 15, 2021 3:17 pmas above Lorenzo set the elevation in the setup screen no need to edit files anyway you have it working but future reference if you see *new setup option mentioned in change log’s it means there is a new option to set.lorenz1982 wrote: Mon Nov 15, 2021 9:59 amI solved.lorenz1982 wrote: Mon Nov 15, 2021 9:43 am
How can I do?
I thought I could edit it later.
Hello Ron can you pm password to setup you can change at anytime..i cant reproduce it locallyrzelle-K1TTC wrote: Mon Nov 15, 2021 4:03 pm Brian,
Hope all is well ..
.. Ron
TheoH
- Fresh Boarder
Hello Brian,
I had exactly the same issue as Ron. Applied the update as normal. But after the update no access to template and none of the related pages. Same error 505 and 404. Had to reinstall the complete package (stupid me latest backup from May ;-( ) But now have the issues that my yearly charts are messed up. The previous months CSV files are still there but not loaded into the yearly charts. Is there a way to do so??
Thanks and keep up the good work.
Good afternoonTheoH wrote: Tue Nov 16, 2021 10:51 am Hello Brian,
sorry for the inconvenience but after spending an hour trying to reproduce this locally and having accessed a few end user sites where permission granted , I couldn't reproduce the problem once on any sites or locally . So I deliberately set the file permission to locked (no write permissions 644) and I was able to create an 505 Access is Denied when the file was locked . So I hope that helps and worth checking the file permission status .
If you did not do a backup prior to updating and you have since overwritten the install then Im afraid its gone sadly..
If you run into any problems in the future leave it has it is and drop me a PM with a url I can resolve most issues or advise what todo if its at server level.
Change Log 16th November 2021
* (12:30) * Contains all features/fixes from Oct 1st to Nov 16th
* (12:30) * Important new options below require to be set
* (12:30) * Adds requested numerical bearing in compass (Ref Ryan)
* (12:30) * Adds new setup screen option to set elevation (Ref Josep)
* (12:30) * Adds new setup screen option to set 9th position module (Ref Lorenzo)
Doing backups will preserve your chart data and settings in the event of any problems.
When new setup options are added ensure the settings file(console-settings)
is not locked with file permissions on your server !!.
just a simple addition to compass added
- rzelle-K1TTC
I compared my good copy of console-settings to the one saved after adding the 9th module. I found 2 diffrences the 9th module addition ($position9t = "uvindexmod-tablet2.php";) and this statement just below the $lat= line ($elevation =
. I saved the console-settings and when trying to open the main page received a 500 error. I went back into the console-settings file removed the ($elevation =
line and now my site is back up with the 9th module displaying in Alt.
I'm not fully convinced the ($elevation =
is the cause since re-saving the file again could have fixed the permissions??
I haven't tried going into setup again and re-saving to see if it issue re-occurs.
73s ..
.. Ron
73s ..
.. Ron
Ron I have pushed a setup file to GitHub , I cant make this replicate the problem your getting locally so Im guessing which is not always a good thing .please try the setup file and set the elevation , I also noticed you have no UTC value in the settingsrzelle-K1TTC wrote: Tue Nov 16, 2021 3:34 pm Brian,
I compared my good copy of console-settings to the one saved after adding the 9th module. I found 2 diffrences the 9th module addition ($position9t = "uvindexmod-tablet2.php";) and this statement just below the $lat= line ($elevation =. I saved the console-settings and when trying to open the main page received a 500 error. I went back into the console-settings file removed the ($elevation =
I'm not fully convinced the ($elevation =is the cause since re-saving the file again could have fixed the permissions??
73s ..
.. Ron
