lorenz1982
Post by lorenz1982 »
weatherist34 wrote: Thu Nov 18, 2021 1:21 pm
jmontamat wrote: Thu Nov 18, 2021 10:45 am Good morning, overflow in the alt theme.
Hello Josep
I didn't have enough to time to complete this yesterday but ALT theme will be removed as the OS themes will show identical max,min,avg data as shown below . But not sure when I can get this finished need to do the air quality modules but below shows what it will look like . so Im not going to fix that issue you raised . This layout is based on numerous requests over the last few weeks to show max,min,avg alongside graph display dashboard layout and this layout will have the option to set the module positions like in main dashboard.as above don't have time at present and neither do I have a reliable internet connection so not going to take the risk of failed uploads.
below shows the max.min.avg data boxes layout alongside the graphs.
Really good!! I like it!!
MeteoBorgo: www.meteoborgo.it
Change Log 19th November 2021 ** New features **
* (10:24) * Contains all features/fixes from Oct 1st to Nov 19th
* (10:24) * Important please check setup screen for new options
* (10:24) * Important please check elevation is stored in setup
* (10:24) * Important please check new 9th position option for OS themes
* (10:24) * Adds new layout for OS/Auto Themes
* (10:24) * Adds max,min,average data views in new layout
* (10:24) * Alt theme now removed and no longer supported
* (10:24) * Adds return to top icon when in mobile single column view
** Important please double check the elevation is stored in setup screen
and the new UV/Solar/Clock option is set.
Doing backups will preserve your chart data and settings in the event of
any problems.
When new setup options are added ensure the settings file(console-settings)
is not locked with file permissions on your server.
scroll to top only appears in single column mobile view when you scroll down near to bottom of screen (shown below )
Another nice update. I think you are approaching the "perfect balance". :D
jmontamat
Post by jmontamat »
Good morning, a small overlap between the value and the title in various win10 browser modules. I don't know if it could be corrected?
Thanks, great job Brian.
Sin título.png (8.38 KiB) Viewed 7924 times
Bart
Post by Bart »
On November 14, Josef wrote something about cloudbase. The formula he used was undoubtedly correct but it bothered me, in that sense, I understood but I didn't understand it.
The formula calculates the difference between the temperature and the dew point measured at the weather station.
Divide (Corrected, made a mistake in the text formula) that difference by 4.4 and multiply the result by 1000. But 4.4 must be 2.5 if you're calculating in celcius. So my question is. What is calculated when. After all measurements and calculations F to C or... the other way around. Does this apply to all measurements or are measurements converted directly.... But if it is directly converted and used, then the formula in this script is wrong. I think ...
I don't know the script or scripts (nor do I understand them :shock: ), let alone which script is applied when.
Hence my question.
Excuse me in advance if this is a really stupid and weird question.
Have a nice weekend,
Bart
jmontamat wrote: Sat Nov 20, 2021 11:28 am Good morning, a small overlap between the value and the title in various win10 browser modules. I don't know if it could be corrected?
Hello Josep see github..
@Bart dunno :D ask Josep..
jmontamat
Post by jmontamat »
@Bart works for me .... my station is 250m high with many periods of fog when it rains I have observed it well, the formula seems good.
Thanks Brian, everything is correct now. :)
jmontamat wrote: Sat Nov 20, 2021 3:54 pm @Bart works for me .... my station is 250m high with many periods of fog when it rains I have observed it well, the formula seems good.
good , and Bart formula works ok here , i did test numerous times with the site for calculating same values..
@all now question having caught up on some emails this afternoon would you like to have the option of which dashboard layout to choose as default display , most emails want the new os theme layouts as main dashboard but those email requests dont account for everyone so would a simple setup screen option be best way to accommodate this or does it create confusion .
brian
lorenz1982
Hello, for me is really ok the setup screen option, so everyone can choosen the best option for themselves.
Really thanks.
garybridge
Post by garybridge »
lorenz1982 wrote: Sat Nov 20, 2021 11:11 pm Hello, for me is really ok the setup screen option, so everyone can choosen the best option for themselves.
Really thanks.
Plus 1 for me Brian
Gary Bridge MIET, MIPS.
pwilman
Post by pwilman »
Setup screen option to set default would work for me.
Paul
weatherist34 wrote: Sat Nov 20, 2021 4:13 pm
brian
Not an issue for me. Default in Setup or, as present - just use a different URL.
Best wishes,
@Alex
could have sworn you posted last night but I was too tired and fell asleep , this morning the post has gone ?. anyway feel free to criticize Im thick skinned so I take it in the light it is posted , if its constructive ill listen and respond if its someone having a rant then it gets the middle finger !! :-)
we all have viewpoints/opinions just some of us choose to be constructive without insulting or getting irate because we don't get the answer we want..
or hear good things all the time ,imagine if I responded to every request with "Im not clairvoyant" kind of sets the tone of negativity doesn't it ..
anyway I have added back on the basic alternative screen and like you my eyesight isn't fantastic anymore but Im not at the point yet of needing glasses but Im sure in time the day will come.
@paulwilman gawd blimey that's a blast from the past thought you got fed up changed hobbies and took up bird watching :-) good to see your still around..
so in the template there are now 4 layouts to use and for future reference and upcoming layout setup choice option it will be like this and named ..
options ..
Layout 1 the main original dashboard layout
Layout 2 dashboard with chart views and theme switching icon
Layout 3 dashboard with chart views and theme based on OS/Browsers supporting auto dark/light switching
Layout 4 basic dashboard layout with larger font sizes for values no chart views in dashboard but via icon links
this will become an option in December and if no option set it will basically show current main original dashboard .
Change Log 22nd November 2021 ** New features for OS Themes **
* (08:35) * Contains all features/fixes from Nov 1st to Nov 22nd
* (08:35) * Important please check setup screen for new options
* (08:35) * Important please check elevation is stored in setup
* (08:35) * Important please check new 9th position option for OS themes
* (08:35) * Re adds Alternative Basic layout screen Ref Alex
* (08:35) * Template now supports 4 layouts
* (08:35) * Prepares code to have choice of default layout
* (08:35) * New setup options will come in December
setup screen and the new UV/Solar/Clock option is set.
* Doing backups will preserve your chart data and settings in the event of
any problems.
* When new setup options are added ensure the settings file
(console-settings) is not locked with file permissions on your server.
alexeysailman
Post by alexeysailman »
Hi, Brian! Although I deleted my post after writing, thinking that I might hurt you with it. I see you read it anyway. Thank you for listening to my opinion.
alexeysailman wrote: Mon Nov 22, 2021 7:56 am Hi, Brian! Although I deleted my post after writing, thinking that I might hurt you with it. I see you read it anyway. Thank you for listening to my opinion.
good morning Alex as above constructive criticism is always valid thats how the template evolved over time and if I can accommodate your ideas,requests its not a problem ..have a good day..brian
