Avereage Windspeed?
Avereage Windspeed?
Quick Dumb Question... The WDL dial for windspeed is an Average Windspeed - does anyone know what that average time is...? Is it 10 minutes? Thanks!
Re:Avereage Windspeed?
Boris,
Do you by change know what this is - I believe it is the 2nd data element in the clientraw file and is listed as avg windspeed.... Avereage of what time though - 10 minutes....or is it more? Thanks!
skyewright
IIRC the mechanism for the clientraw files basically involves some very fancy HTML templates.AAMFlyer wrote:Do you by change know what this is - I believe it is the 2nd data element in the clientraw file and is listed as avg windspeed....
If I'm correct then if you found those files you'd find the answer?
I think the location of the templates was mentioned on the Forum at some time, but I've not been able to find the relevant message. I you find them I'd be interested to know where they are too.
Failing that have you tried comparing the value against graphs using various "bucket" sizes?
Or maybe studying wind0-min10, etc. in the weather folder?
skyewright
I found the templates (by realising that Linux must have a tool for finding files, and discovering the locate tool...).AAMFlyer wrote:I believe it is the 2nd data element in the clientraw file and is listed as avg windspeed.... Avereage of what time though - 10 minutes....or is it more?
The file is:
\\home\\meteohub\\clientraw.conf
and the first 3 fields (after the initial 12345 marker) are:
[actual_wind0_speed_kn:-] [actual_wind0_gustspeed_kn:-] [actual_wind0_dir_deg:-]
You kind of lost me - somewhere it has to be actually calculating an average and there is no field or meteohub marker for average that I can find.... Comparing to my Davis console - it looks to be a 10 minute avereage as those measure close to each other on the 10 min avg..
When you parse the clientraw file - you get this..
Field# Label Type Contents
000 Header L 12345
001 Avg Speed K 5.2 kts = 5.98 mph = 9.63 km/h
http://www.tnetweather.com/wd-parser.php
I guess I will call it a 10 min avg at this time...
000 Header L 12345
skyewright
A lot the figures are implicitly averages e.g. [last60m_wind0_speed_mph] is the (average) windspeed over the last 60 minutes.AAMFlyer wrote:You kind of lost me - somewhere it has to be actually calculating an average and there is no field or meteohub marker for average that I can find....
From my earlier analysis, the meteohub value being used is [actual_wind0_speed_kn], which I believe is the most recently received windspeed reading in knots.Comparing to my Davis console - it looks to be a 10 minute avereage as those measure close to each other on the 10 min avg..
Edit: Because the Davis VP2 issues wind data at such a high rate, I have a feeling that 'actual' may have a slightly different meaning in that case in order to prevent excessively large Meteohub raw data files? Perhaps a 1 minute average?
That's a good point on the Davis.... I always thought it was simply taking the most recent reading (which for the Davis is every 2.5 seconds) - but then WDL labels it as Average Windspeed....so it would be nice to know what the avg really is....
Perhaps Boris can chime in hear to see what that "actual_wind0_speed_kn" really is when adding it to the clientraw file...is the a snap shot or the most current reading or an average over 1 min, 10 min etc.... But so far it seems to match the 10 min avg on the Davis Console....
Thanks!
Thanks!
