Best wishes for a speedy recovery.
Take care,
jmontamat
Post by jmontamat »
It was a curiosity, I work with meteobridge [lgt0total-nonzerotime: -] and it works for me.
Take care of your health and recover soon.
pwilman
Post by pwilman »
wishing you a speedy recovery too Brian.....
Paul
xray77
Post by xray77 »
Hello Brian,
also from me best wishes to you! Have a speedy recovery and a peaceful and healthy pre-christmas-time!
regards
Mike
default layout added as requested ..thanks all for the well wishes ..
Change Log 13th December 2021 ** Now supports 4 Layouts **
* (13:41) * Contains all features/fixes from Nov 6th to December 13th
* (13:41) * Adds requested default layout setup option
* (13:41) * Adds 5 minute wind direction trend
* (13:41) * Numerous files cleaned up Dev code
** 13th December 2021 Important please set new default layout option.
* Doing backups will preserve your chart data and settings in the event of
any problems.
* When new setup options are added ensure the settings file
(console-settings) is not locked with file permissions on your server.
The optional and default layouts are a nice addition. :D Did you decide to remove the Tool tips (layout definitions) in the latest update?
Hope all is well.
jmontamat
Post by jmontamat »
Good idea to choose the themes separately but.
layout definitions was a guide for the user who does not know what they are.
Hope all is well.
prestwickwx wrote: Tue Dec 14, 2021 4:38 pm Hi Brian,
Hope all is well.
@Chuck /Josep
Sorry minor oversight just added back on(GITHUB) . yes all is well apart from the medication at times feel like Im more spaced out than Neil Armstrong ever was :wink: ..
OK. Got it.
Glad to hear you are on the mend. :D
Thanks again,
jmontamat
Post by jmontamat »
Thank you, I'm glad you are better,
Medications the less the better ...
I have been checking out the sidemenu on mobile and I noticed a difference in spacing (padding) between the items. When I select the Alternative Tablet Layout or the original Basic Layout the Menu items have more spacing than when I select the Detailed Layout. The Detailed Layout menu spacing seems optimal because it allows more menu items before running out of space on the Mobile screen.
Not a big deal and maybe I am the only one that has too many menu items. I just noticed it since the new Layout Options choice takes a couple of menu lines.
prestwickwx wrote: Tue Dec 14, 2021 9:10 pm Hi Brian,
Good Morning Chuck
check your modification perhaps edit the sidemenu file that was uploaded to GITHUB yesterday. your units don't reflect the change to show tooltips see screenshot compared to Rons using the GitHub file . hope that helps..Brian
Ok. I did grab the latest Menu file and picked up the Units Tool Tips. It didn't have any effect on the padding between the menu items that I was referring to. I think this must be a difference in the css files between the the Detailed Layout vs the Alternative and Basic. Looks like there is more space between the Menu items on the Basic and Alternative compared to the Detailed Layout.
Its not a big problem - only effects the mobile version and I can always remove a few Menu items.
IMG_0104 (Small).jpg (83.18 KiB) Viewed 7516 times
IMG_0103 (Small).jpg (70.14 KiB) Viewed 7516 times
ok chuck im not getting this one locally it is identical css for layouts,units section across the css files .. that said windy iframe is due for removal and rainviewer as future browser releases will block third party cookies , when they release this other iframe types that request cookies will get a default nag message from browser not template , bit like when https warning first started to appear, ive always said dont scrape wont scrape 😁 ..third party means when request is not requested by the original domain url i.e your domain or offsite request will be interesting how that reacts to those that use third party cloud scripts..anyway i will take a closer look his evening see if I can reproduce it and let you know..
weatherist34 wrote: Wed Dec 15, 2021 4:10 pm ok chuck im not getting this one locally it is identical css for layouts,units section across the css files .. that said windy iframe is due for removal and rainviewer as future browser releases will block third party cookies , when they release this other iframe types that request cookies will get a default nag message from browser not template , bit like when https warning first started to appear, ive always said dont scrape wont scrape 😁 ..third party means when request is not requested by the original domain url i.e your domain or offsite request will be interesting how that reacts to those that use third party cloud scripts..anyway i will take a closer look his evening see if I can reproduce it and let you know..
The spacing anomaly seems to show up in all of the browsers that I have tried. Yes. I can hear the advertisers wailing already. :D
