ok i think i see what your pointing out now , the difference between each menu link differs from original theme to os themes .push a fix later..
Change Log 16th December 2021 ** Now supports 4 Layouts **
* (09:37) * Contains all features/fixes from Nov 6th to December 16th
* (09:37) * Minor rework on menu layout Ref Chuck
* (09:37) * Adds rain last hour if greater than zero Ref Tom Ingoldsby
** 14th December 2021 Important please set new default layout option.
* Doing backups will preserve your chart data and settings in the event of
any problems.
* When new setup options are added ensure the settings file
(console-settings) is not locked with file permissions on your server.
Menu item padding - All fixed. :D Works fine on all layouts.
Thanks again,
prestwickwx wrote: Thu Dec 16, 2021 4:06 pm Hi Brian,
Thanks again,
Ha good I wasn't sure if I cracked it. I had a tough time trying to replicate your scenario but tried a few things in hope :-)
I forgot to mention template is 100% verified with PHP 8.1 with no changes required to meet compatibility , I installed a localized version around 29th
November during my recovery also thinking I would have to make changes somewhere but thankfully there was no changes required. My advice to anyone dabbling in latest PHP releases in advance make sure the required PHP modules are enabled occasionally you will stumble across installs that don't always have various modules enabled.Always do a back up of your server install if possible , new PHP revision releases can unintentionally break things and send you round in circles only to find a required module was not enabled.Dont always be too quick to jump if your running server publicly sometimes your the last to know.I religiously try to keep on top of PHP releases locally only .
don't forget you can always check your hosted PHP version in the template ..
jmontamat
Post by jmontamat »
Good evening, air quality overlay on Purpleair.
The rest all good. :D
Thank you.
Sin título.png (26.73 KiB) Viewed 6607 times
jmontamat wrote: Thu Dec 16, 2021 7:57 pm Good evening, air quality overlay on Purpleair.
Thank you.
Good morning Josep
thanks ive adjusted the format to no decimal when value reaches 100 or more .pushed to GITHUB .. as below
jmontamat
Post by jmontamat »
Good morning, Thanks Brian. :)
last update or addition based on requests for 2021 . its holiday time and time to refresh and hopefully next year more ideas will evolve or come to mind.
Change Log 18th December 2021 ** Now supports 4 Layouts **
* (11:38) * Contains all features/fixes from Nov 6th to December 18th
* (11:38) * Final Update for 2021
* (11:38) * Adds windchill if less than 1c or 33.8F Ref S Hawkes
any problems.
jmontamat
Post by jmontamat »
Could it also be done for heatindex?
jmontamat
Post by jmontamat »
Hi brian, if barormeter Rapidy Falling appears this.
Thank you.
Sin título.png (15.78 KiB) Viewed 6480 times
jmontamat wrote: Sun Dec 19, 2021 4:09 pm Hi brian, if barormeter Rapidy Falling appears this.
Thank you.
good morning Josep thanks another minor oversight of using if or if else but unfortunately i cant or wont be pushing updates till 4th January.. im sure you can live with that one for a wee bit.. heatindex sure but next year..have a good festive season and thanks for your continuous help over the years..brian
jmontamat
Post by jmontamat »
weatherist34 wrote: Tue Dec 21, 2021 9:08 am good morning Josep thanks another minor oversight of using if or if else but unfortunately i cant or wont be pushing updates till 4th January.. im sure you can live with that one for a wee bit.. heatindex sure but next year..have a good festive season and thanks for your continuous help over the years..brian
A pleasure to help you happy holidays.
Bart
Post by Bart »
Is this a bit confusing? What do we mean by wind chill?
The term Windchill is confusing anyway, so there are several formulas for it. In general, this refers to a temperature that one experiences as a result of a combination of the low temperature in combination with, in particular, the wind.
In a formula it quickly becomes a separate concept. A temperature that reflects the human experience of heat loss.
But two different values..... I have the impression that the lower value (-5.4°) is incorrect or at least does not do justice to the term windchill.
But I could be wrong.
Anyway have a nice day for now.
Merry Christmas in a few days.
Bart
Schermafbeelding 2021-12-21 om 08.59.50.png (198.37 KiB) Viewed 6382 times
Change Log 21st December 2021
* (13:40) * Contains all features/fixes from Nov 6th to December 21st
* (13:40) * Enjoy the festive season Final Update for 2021
* (13:40) * Please if you find any anomalies just hang on till 4th January
* (13:40) * Till then just enjoy the festive period......
* (13:40) * Windchill Ref Bart
* (13:40) * Pressure rapid rising,falling phrase tooltip Ref Josep
any problems.
Take this opportunity wish every one a merry Christmas and a healthy prosperous 2022 ..
for the PHP conscious :-) before you ask
yes PHP 8.1.1 verified ..
