Hello, i am new with the software meteohub. I use now a trial version from meteohub (4.1, with 2 days left). My Weatherstation is a WMR-200. I connectet the WMR with the USB-cable to the nslu. I configurate the sensors an make a export in the wd export option.
But how can i import this cvs file in the WD-Software. If i open the file with wd, no datas are shown. The WD-Software is the software from oregon. Or is this not possible with this software?
Thank you for your help.
Michael
Import WD Datas from NSLU
skyewright
Re:Import WD Datas from NSLU
The "free" Weather-Display Basic that comes with the WMR200?struppi wrote:The WD-Software is the software from oregon.
If so:
a) It is only designed to be used with direct connection to the WMR200.
b) It's probably a very old copy.
Even if you intend to stick with Weather-Display Basic you are strongly recommended to update.
This link explains the role of Weather-Display Basic and provides an update link.
Not impossible, but...Or is this not possible with this software?
The best mode of Meteohub to WD communication is the "logging protocol". This link takes you to an FAQ about that.
