Adrianwx23
- Junior Boarder
Hi guys, i would like to see my Tempest data on the weather34 template but i am a little confused as to were i get the API or path for my Meteobridge to upload? Also what interval do i set it at?
Any help will be greatly appreciated. This is the weatherbridge i have.
https://ambientweather.com/amweatherbridge.html
Good morning I seem to recall there was something different with the ambient weatherbridge versions can't recall exactly what it was its been many years but may be the weather34 API option is not viewable in these ambient version as they promote and sell there own API service .please feel free to correct me wrong anyone I really can't help much in regards to AMBIENT weather stuff.Adrianwx23 wrote: Mon Dec 27, 2021 11:22 pm Hi guys, i would like to see my Tempest data on the weather34 template but i am a little confused as to were i get the API or path for my Meteobridge to upload? Also what interval do i set it at?
the setup guide is the same for any weather station compatible with meteobridge though some brands like ecowitt are not fully supported where extra sensors are in use . have a read of the simple setup guide .
https://weather34.com/homeweatherstatio ... guide.html
The update released on the 28th requires the setup screen to be run as discussed in recent threads.This is important !!! so please run the setup screen.
Change Log 28th December 2021 ** Requires to run setup screen **
* (10:42) * Contains all features/fixes from Nov 6th to December 28th
* (10:42) * Adds new UTC to automatically recognise DST Ref Josep
* (10:42) * Important run setup screen to clear existing UTC offset
* (10:42) * See screenshot below to clear existing UTC offset
* (10:42) * PHP 8.1.1 verified 22nd December
** 28th December 2021 Important please run the setup to clear existing
UTC setting screenshot shown below.
Clear UTC Screenshot
* Doing backups will preserve your chart data and settings in the event of
any problems.
* When new setup options are added ensure the settings file
(console-settings) is not locked with file permissions on your server.
Thanks for the new automatic UTC time change function, then I will have to update the template on my server again in January
- jmontamat
I have added this to control its proper functioning....
Good new year everyone.
- Sin título.png (16.98 KiB) Viewed 8463 times
ok Josep nice touch added to GITHUB just now but not worth updating simple update as day is almost over it will confuse .jmontamat wrote: Tue Dec 28, 2021 4:07 pm I have added this to control its proper functioning....
blue for 0 or negative difference
red for positive or ahead
- jmontamat
Thanks Brian, I knew I would do better than me.
Adrianwx23
- Junior Boarder
weatherist34 wrote: Tue Dec 28, 2021 9:58 amGood morning I seem to recall there was something different with the ambient weatherbridge versions can't recall exactly what it was its been many years but may be the weather34 API option is not viewable in these ambient version as they promote and sell there own API service .please feel free to correct me wrong anyone I really can't help much in regards to AMBIENT weather stuff.Adrianwx23 wrote: Mon Dec 27, 2021 11:22 pm Hi guys, i would like to see my Tempest data on the weather34 template but i am a little confused as to were i get the API or path for my Meteobridge to upload? Also what interval do i set it at?
any problems.
Hello thanks for the reply yea in my meteobridge it asks me for an API and i was not sure were to get that. From what i know my meteobridge is not using any api, it listens to my local network to capture the data coming in via UDP. Sorry for the dumb question Do i need my own website to run this or can i use the API from wunderground?
- Capture1234.JPEG (39.93 KiB) Viewed 8446 times
good evening
yes you need a website and the API url is a domain url not an API key.
if you have a web site follow this guide https://weather34.com/homeweatherstatio ... guide.html
sorry doesnt use anything for weather station data from weather underground, all is used is the forecast but that itself will change in 2022 sometime.
brian..have a good day..
Adrianwx23
- Junior Boarder
weatherist34 wrote: Tue Dec 28, 2021 7:55 pm good evening
any recommendations for cheap/non expensive websites or hosting services that can be used to run this? So the website URL goes into that box in the meteobridge?
Good evening,
Why is there a difference in PM 2.5 and PM 2.5 in chart data (graphs).I can't find the info on the 2nd screenshot in the Davis Weatherlink data either.
Bart
Bart
- Schermafbeelding 2021-12-30 om 20.37.16.png (38.53 KiB) Viewed 8349 times
- Schermafbeelding 2021-12-30 om 20.36.24.png (42.98 KiB) Viewed 8349 times
- prestwickwx
Hi Bart,
That confused me, at first, as well. I think the 24.2 is the AQI (EPA) rating using PM2.5. The 20.6 is the actual PM2.5.
Hello, Chuck,
Yes, must be that, but it is somewhat confusing indeed. Quite apart from the fact that those measurements exist separately, especially in the utterance. not only here but also in other places, f.i. Davis. Cannot find it in the Meteobridge.
Bart
Bart
garybridge
- Expert Boarder
I can't seem to get at Today's update...
MediaFire tells me it is missing when I click on today's update on Brian's site.
If anyone else can help me to get the zip I'd be very grateful !!
Happy New Year to you all !
garybridge
- Expert Boarder
Panic over... It has re- apppeared !garybridge wrote: Fri Dec 31, 2021 7:34 pm I can't seem to get at Today's update...
- jasonmfarrow
In the various charts, "yesterday" and "last month" are not working but "last year" is. Possibly a 2022 vs 2021 issue given that this is the first year-up since this functionality was added. The december.csv and 31dec2021.csv files are good from a content pov.
FYI: update31-12-2021.zip is applied.
