Unable to connect to Meteobridge. **solved**
ajkelsey
Post by ajkelsey »
I purchased a Weatherbridge from Ambient Weather a few years ago. It's a TP-Link TL-MR3020 running Meteobridge). I made some network changes and had to reconfigure my Weatherbridge. I first attempted to reset the ip address to default and tried resetting to factory defaults. It still won't acquire an ip address. Any insight would be appreciated.
masgio69
Re: Unable to connect to Meteobridge
Post by masgio69 »
Have you tried to do an ip scan of your network? Maybe he just changed his address and you don't see him at the address he used to be. Are the LEDs on the ethernet cable flashing?
ajkelsey
Post by ajkelsey »
I tried scanning. The activity light does blink on the ethernet switch. It was originally set to static IP, but it should be DHCP after the factory reset.
ajkelsey
Post by ajkelsey »
Ok. I figured it out. It was a misconfiguration in my switch. 🤦‍♂️
